V6 oil leak
Posted: Tue Apr 15, 2014 8:16 am
by Dotty1971
I have a Ford Freda V6 which has developed a misfire...after checking the HT leads I have found oil in both the os and ns end leads...does this sound disasterous or is it an easy repair..I am also on holiday and need to tow my caravan home is this advisable....
Re: V6 oil leak
Posted: Tue Apr 15, 2014 8:49 am
by wonkanoby
they often seem to leak from rocker cover gasket
check all bolts are tight
in the end might need new gaskets
Re: V6 oil leak
Posted: Tue Apr 15, 2014 10:19 am
by Dotty1971
Managed to soak the oil up and dry out..rocker bolts were loose.....now tightened leads clean and dry..no misfire... will run today and recheck...fingers crossed....many thanks..
Re: V6 oil leak
Posted: Tue Apr 22, 2014 12:43 pm
by Grahame at work
you should note that the rock cover bolts only require a bit more than finger tight to meet the spcification as they have rubber seals on each one that will break if over tightened.
Regards Grahame
