Temp Sender
Posted: Thu Mar 27, 2014 10:02 pm
				Evening all
Has anyone any experience of the Lucas temp sender for the temp gauge as mine in knackered but need to get it replaced tomorrow so was thinking of going to my local motor factors to get one.
Alternatively I could go to Ford parts and see if they have one for the ranger head as the nearest mazda dealer is 20 miles away.
This will give you an idea of how useless the temp gauge is before the mod. Since we got the freda once up to temp the gauge would show about 11 o'clock, I did the mod with no other changes to find the needle all over the place.
So I decided to check the sender and the centre of the sender is loose in it's housing causing the needle to jump about as it was shorting out.
David
David
