				Where is my bleed pipe, it's missing
				Posted: Tue Mar 25, 2014 1:17 pm
				by Sparky6911
				Hi All
I have been in discussion with a number of people on here for doing a coolant change and installing the coolant alarm/temp gauge
I've been studying this picture trying to find the coolant bleed pipe but I just don't have it.
I don't even have the port on the head for it.
Was there an updated had used as this has obviously had a new head. Can anyone give me a pointer on bleeding this system
David
				Re: Where is my bleed pipe, it's missing
				Posted: Tue Mar 25, 2014 2:06 pm
				by dave_aber
				That will be a Ford Ranger head - as they have a more conventional position for the engine, there is no bleed pipe or port.
No idea myself how you will bleed it - you could use a vacuum fill system to fill it without the need to bleed though.
(Only advisable if you are 100% sure that there is nothing wrong with the cooling system)
				Posted: Tue Mar 25, 2014 2:33 pm
				by Sparky6911
				Oh Joy, i'm wondering if a junction added to the T-Piece will do it? or if a port could be added to the head?
I was really looking forward to owning this but now worried I might have bought a dufer.
				Posted: Tue Mar 25, 2014 2:50 pm
				by Sparky6911
				Just done a bit of searching and it seems this is not actually that uncommon.
is it really just as simple as swapping the 2 branch t for a 3 branch?
or can a t be added to the small pipe running to the turbo?
Thanks again
david
				Posted: Tue Mar 25, 2014 3:36 pm
				by Simon Jones
				Speak to Ady / Northern Bongalow, he has experience of bleeding these I believe.
				Posted: Tue Mar 25, 2014 3:53 pm
				by Sparky6911
				Awesome thanks guys. I have now ordered a 3 branch elbow so going to do a coolant swap while i am at it.
				Posted: Tue Mar 25, 2014 6:44 pm
				by Sparky6911
				Hi Simon, does Ady have a Bongo business as I can't find details of him anywhere.
David
				Posted: Tue Mar 25, 2014 9:09 pm
				by Simon Jones
				He usually has a spare cylinder head or two under the bed
. I'm sure he'll be along soon, but you can pm him:
http://www.igmaynard.co.uk/bongo/forum/ ... ile&u=7597
				Posted: Tue Mar 25, 2014 9:13 pm
				by Northern Bongolow
				no i dont have a business sorry.
when i do these i just add a tee piece and bleed pipe to the turbo pipe, it works well, fit it near the head end.
use the proper clips too, dont use cheap jubliee type clips.
				Posted: Tue Mar 25, 2014 10:45 pm
				by M 80NGO
				Bled mine via the turbo coolant pipe, the rubber pipe fits nicely inside a length of hose pipe then wedge the funnel in the top of the hose, wear thick rubber gloves and hold your thumb over the metal pipe coming out of the turbo.
				Posted: Tue Mar 25, 2014 11:09 pm
				by Sparky6911
				You guys are great, thanks for all your help.
David
