Top Hose Replacement
Posted: Fri Feb 28, 2014 2:41 pm
I was driving back from Cardiff in the Bongo last week when the low coolant alarm did it's job! I stopped and investigated. It was a split hose. The top hose directly under the driver's seat. I called the RAC and they made a temporary repair which got me home. I've ordered and received a replacement hose but I'm not sure of the exact procedure to replace it and bleed the system adequately. I'm told that it's not necessary to drain and replace all the coolant as it's only the top hose that's gone. As I've just had the coolant changed and other hoses replaced recently, it seems a shame to go through it all again!
But if that's what it takes???
Grateful for any opinions from wiser heads than mine.
