reverse gear
Baz and Helen
reverse gear
Post by Baz and Helen » Fri Feb 14, 2014 3:25 pm
Hi hope someone can give me some advice, went out in the bongo today everything seemed to be running fine but when I went to reversed it wouldent do it. I had reversed earlier and it was fine, but now it wont go backwards. I wonder could it be something simple or am I looking at a new gearbox. Would be grateful for any advice
many thanks
Baz
Re: reverse gear
Post by Bob » Fri Feb 14, 2014 3:36 pm
Did the selector move to the R position, then Bongy not move, or would the selector not engage?
Edit: Have you checked the gearbox oil level?
Baz and Helen
Re: reverse gear
Post by Baz and Helen » Fri Feb 14, 2014 4:25 pm
Hi Bob , the selector did go into position but the van would not reverse, but driving forward is fine
Re: reverse gear
Post by Northern Bongolow » Fri Feb 14, 2014 7:59 pm
i would try an oil change if its not been done.--------------------- but.
http://lushprojects.com/bongopartsmk2/c ... 02.html#42
Baz and Helen
Re: reverse gear
Post by Baz and Helen » Sat Feb 15, 2014 2:34 pm
Hi have checked the oil, everything there seems fine, clean and full. I think its going to be another gear box, thanks for your help much appreciated
baz
helen&tony
Re: reverse gear
Post by helen&tony » Sat Feb 15, 2014 3:24 pm
Are you positive that the cable moved the gearbox into Reverse at the box end?
If you're sure, check out the information on "solenoid pack" in the search facility...I' no expert on auto boxes, so I can't say whether the solenoid pack controls reverse....if it does, I believe it's not a hard job, and won't cost too much....here's hoping [-o<
Baz and Helen
Re: reverse gear
Post by Baz and Helen » Sun Feb 16, 2014 1:12 pm
Hi checked that the reverse gear was engaging and it was. then tried to reverse and it went backwards, but then tried again it wouldent do it. I have looked underneath and there is a leak on the return pipe to the gearbox. Do you think this would stop it reversing.
Any ideas would be appreciated
thanks baz
helen&tony
Re: reverse gear
Post by helen&tony » Sun Feb 16, 2014 3:22 pm
You might have answered your own query!...see if you can cobble a temporary repair to the pipe, then if it works, get a new one!
