Coolant Change and Flush
Posted: Tue Feb 04, 2014 1:14 pm
by Mini Men
Hi, time to change the coolant given we have no idea what's in the van or how long its been in. So I have my red stuff ready to go and have watched the video and info sheets. However guessing I need to flush everything out given we don't know what's in already. Is this something you can do DIY and how?
Re: Coolant Change and Flush
Posted: Tue Feb 04, 2014 1:53 pm
by wonkanoby
yes its diy and messy
you can find different ways on u tube
but bear in mind bongo has har more pipes and heaters to collect sludge
than most regular cars
start by removing rad cap and bottom heater hose to rad to get bulk out
then start the flushing with a hose pipe
extent depends on how far you want to go
you can for instance back flush front and rear heaters by removing hoses local to them..you will be amazed at the crud
back flushing is forcing fluid in the opposite way to its normal flow
the 2x steel pipes connect the rad to the engine area also tend to have lots of crud in them
you can remove hoses at both ends
you could evan rod them through like a drain
be carefull removing pipe as to likes of rear heater its easy to break things
Posted: Tue Feb 04, 2014 9:02 pm
by Northern Bongolow
as above
. get as many hoses off as possible then flush,be careful of those connected to the front and rear heaters the stubs of the heaters are made of plastic and can be brittle.
Posted: Tue Feb 04, 2014 11:01 pm
by Simon Jones
If you've got an old hose you can modify with a hose fitting so you can connect it up to the tap and reverse flush water thru the radiator to come out the header tank.
Posted: Wed Feb 05, 2014 12:08 am
At the risk of being controversial, will there be crud if a system has been properly maintained. I've never seen a hint of crud in mine
Posted: Wed Feb 05, 2014 12:22 am
by Simon Jones
If its been properly serviced from new and no bits of metal, plastic or rubber have worked loose from within the system then you could be totally crud free. Typically it silts up the radiator matrix so you are unlikely to see anything obvious when you do a coolant change.
It also depends what water has been used in it. Our kettle at home has calcium deposits in it (limescale) and the shower head nozzles frequently need unblocking. The Bongo engine is effectively a giant kettle but without the advantage of water being replaced every day.
You can also get a chemical reaction if you mix two incompatible types of coolant which can result in a cloudy gel forming which will block the smaller passages.
