Page 1 of 2
				Good news and Bad news ... looking for help!
				Posted: Fri Dec 06, 2013 6:22 pm
				by AeroNut
				The good news... my gearbox has finally been rebuilt....
The bad news.. driving it home it seems the coolant pipes have failed and I sat on the side of the road waiting recovery..
The help I need is to understand the coolant pipe routes.. I have a large pool of coolant on the floor just behind the drivers door. looking underneath there are two pipes that turn upwards into the floor. They are very wet....the fluid coming out is definitely engine coolant...
lots of it.....
Any suggestions to start me off?
Regards
Terry D
				Re: Good news and Bad news ... looking for help!
				Posted: Fri Dec 06, 2013 6:40 pm
				by mikeWalsall
				Scroll down for a routing of the plumbing ..
http://mazdabongo.wikispaces.com/Parts
				by Driver+Passengers
Scroll down to "HEATER PIPES" and "REAR HEATER PIPEWORK".
				Posted: Fri Dec 06, 2013 6:43 pm
				by rita
				Looks like your rear heater matrix could be gubbed or a faulty hose/connector.
Have you checked the level in the header tank.
				Posted: Fri Dec 06, 2013 7:08 pm
				by AeroNut
				rita wrote:Looks like your rear heater matrix could be gubbed or a faulty hose/connector.
Oh yes, its emptied itself twice... the second time in about a mile.... and I could trace where I came from..... sadly
TJD
				Posted: Fri Dec 06, 2013 7:33 pm
				by ffrank
				this coolant is on the deck outside (yes)
if so had same problem.
leak was stopped by adding another jubilee clip
beside original.
did not remove origonal clip as was very tight
and did not want to risk any other damage to hose or connection point
				Posted: Fri Dec 06, 2013 8:00 pm
				by Peg leg Pete
				Once you get the pipework sorted, a coolant bleed may be needed!
				Posted: Fri Dec 06, 2013 8:20 pm
				by Bob
				Really bad luck, Mate.
Worth sticking with Bongy, though.
				Posted: Sun Dec 08, 2013 12:33 pm
				by tallbongo
				Defintely sounds like the rear heater pipework or the heater itself. I've recently had a similar problem (still not fixed fully). Check both the steel and rubber pipes in addition to the connections. In my experience I've had more problems with metal pipes corroding (not just the Bongo) than rubber failure.
16mm radiator pipe should help make a temp fix and you will definitely need to bleed the system if you break into it around this area. I can't see how it's possible to not let air in.
There are some details of the pipework routes in my thread
http://igmaynard.co.uk/bongo/forum/view ... =3&t=63537 alongside some suggestions on how to bypass the rear heater if that's the culprit. So far I've cut out all the bad metal I can find and replaced with 16mm radiator hose. I still have a very slow leak though that I need to track down before I can say it's fixed (or there was still air trapped after the bleed).
				Posted: Mon Dec 09, 2013 1:44 pm
				by AeroNut
				Ah ha...
  Found the blighter... The rear heater rad matrix has fallen to pieces (I think)
  The full contents of the engine empties itself in less than a minuite..! Directly as I pour it in it comes out almost...
 Made a temp' plumbing job to bypass the heater you'd all be proud of??
  Now looking for a new rear heater matrix? How hard can that be?
Thanks for you assistance...
Regards
Terry D
				Posted: Mon Dec 09, 2013 2:24 pm
				by wonkanoby
				Posted: Mon Dec 09, 2013 3:20 pm
				by mikeWalsall
				Posted: Mon Dec 09, 2013 3:36 pm
				by dunslair
				Refurbished or new I think these folks should be able to hepl. Worth giving them a call.
http://www.vehicleheaters.co.uk/
				Posted: Mon Dec 09, 2013 3:48 pm
				by mikeWalsall
				I 'Think' both the links are the same Company .. but like you say .. worth a try ..!!
http://www.demisterman.co.uk/index.php
				Posted: Mon Dec 09, 2013 5:01 pm
				by dunslair
				Sorry Mike, your link did not work when I tried it earlier.
