Excessive play in wiper arms
Posted: Wed Nov 27, 2013 11:02 pm
by lerjulian
Hallo to all on the forum - I'm very pleased to meet you. I recently acquired a 2000 2.0l petrol tin top - and the whole family is delighted with it! It's perfect for carting around a family of six. We do like our Japanese imports - our previous bus was a '96 Toyota Estima.
Anyway, there is just one issue so far - there is excessive play in the front wipers. I found a couple of historic posts on this problem, including a very handy parts diagram, but I am still a little unclear on the solution.
To correct this, would you say I need a new wiper motor, or new linkage rods ... or both?
Thanks very much, Julian.
Re: Excessive play in wiper arms
Posted: Wed Nov 27, 2013 11:43 pm
by Simon Jones
Welcome aboard :). I think these will resolve the problem as the nylon 'knuckles' tend to wear out: http://www.ebay.co.uk/itm/MAZDA-BONGO-M ... 27db0dcd78
Posted: Thu Nov 28, 2013 12:00 am
by lerjulian
Simon, thanks very much for your reply. The apparently simple installation certainly makes them worth a try! Just ordered them .... so fingers crossed.
Posted: Tue Dec 31, 2013 2:37 pm
by lerjulian
Hi all, happy new year.
I just attempted to replace the wiper link rods, but had a problem. The bolt circled in red in the diagram below rotates as I turn the nut. Access to the underside is extremely limited ... any hints on how I can keep the bolt still and remove the nut?
http://s129.photobucket.com/user/julian ... sort=3&o=0
Thanks! Julian.
Posted: Wed Jan 15, 2014 9:49 pm
by lerjulian
Hi all, just wondering if anyone has a nugget of advice about this. I think I'm going to have to drill out the rusty bolt on Saturday and thread a new one of similar size through the plastic casing. I am a little concerned that this approach will affect operation of the wipers, so other views are very welcome before the weekend!
Posted: Wed Jan 15, 2014 10:44 pm
by Northern Bongolow
get the nut off anyway you can, like grinding or drilling. they usually snap off so you are unlucky #-o :wink: then the unit will come out from the rear. the bolt i think is simple to replace. you can see in the diagram that the bolt slides into the slotted mounting bracket, it has a rubber mount round it, the whole lot just slides out sideways along the slots. (if i remember right) #-o
Posted: Fri Jan 17, 2014 2:13 pm
by lerjulian
That's very reassuring, Northern! Thanks very much for your help - will grapple with it again this weekend.
