In France - rear exhaust fallen off - advice appreciated!
JudeSunFlower
Post by JudeSunFlower » Sun Oct 27, 2013 5:55 pm
The rear section of my exhaust fell of my 1999 Mazda Bongo (2.5 TD) this afternoon. :( The pipe to the rear box has broken where it joins the box. Normally I'd just order another and arrange a fitting.
I have taken off the box which is still in reasonable shape and have the rubber fittings. It just needs to get my family and me through a few more days pottering about and a 200 mile drive back to the ferry.
Has anyone ever tried to get a Bongo exhaust supplied and repaired in France? If so do you have any advice - where to go etc.? I cannot really drive any distance with things as they are. I am worried nowhere will stock what I need and UK ordered parts are unlikely to arrive before I need to travel home.
Alternatively - can anyone recommend any temporary repairs?
Is it safe to drive a significant distance without the rear box fitted if I can secure the broken pipe?
I am in St Brieuc (Brittany). Thank you in advance.
(Re-posting here - apologies for duplication.)
Re: In France - rear exhaust fallen off - advice appreciated
Post by Bob » Sun Oct 27, 2013 5:57 pm
I'm happy to be blamed for the duplication. 8)
Gasy
Post by Gasy » Sun Oct 27, 2013 6:14 pm
If you carny get one locally
I'd drive it back like that
If you get smells coming into van just extend what's left of your eggsaust with flexible metal ducting
Should be able to get that from a local auto store
winchman
Post by winchman » Sun Oct 27, 2013 6:26 pm
French back street garage should be able to bodge it to get you home.
briwy
Post by briwy » Sun Oct 27, 2013 6:27 pm
This may help, Feu Vert is like the Halfords of France. This is the branch close to you.
http://centres.feuvert.fr/centre-feuver ... 23c69610f8
They may be able to fit a generic silencer on to get you going or cobble up the old one.
JudeSunFlower
Post by JudeSunFlower » Sun Oct 27, 2013 6:51 pm
Thank you all for your replies. Really impressed with this forum!
I'll let you know how I get on...
dom_e
Post by dom_e » Mon Oct 28, 2013 7:51 am
Depending on how far you have to drive, it may not be necessary. I've driven a few hundred miles without a back box with no issues in my diesel.
Beyond A to B
MarcT77
Post by MarcT77 » Mon Oct 28, 2013 9:43 am
A good temporary fix is to split a drinks can wrap it round the pipe and jubilee clip it into place.
Mine went a few weeks ago and this bodge saw me thru till pay day...
Velocette
Post by Velocette » Mon Oct 28, 2013 11:16 am
MarcT77 wrote:A good temporary fix is to split a drinks can wrap it round the pipe and jubilee clip it into place.
I think it is snapped off at the weld where pipe is perpedicular to flat end of box. I used the drinks can dodge on the other end of my tailpipe where it shows at the bumper. Looked quite bling and got another year out of the backbox! :)
Diplomat
Post by Diplomat » Mon Oct 28, 2013 12:02 pm
It's almost a certainty with this design that the join will fail where the pipe is welded into the back box. There is so much weight applied at this point, with some twist for good measure. The twist becomes apparent when you try inserting a piece of mating diameter tubing to try and make a temporary fix.
If you haven't got welding gear, forget it. It's not worth the aggro of trying to fix it when it will run fine and pass the test without a back box as long as the pipe extends to the rear extremity of the bodywork.
Because of this inherent weakness, I meant to fit an additional hanger at the front of the box to take the weight soon after I fitted a new exhaust. That was 3 M.o.T. s ago. Must do it soon before the next catastrophic failure occurs. There is a handy place to secure it to on the bodywork above. Some stout wire and a rubber loop is sufficient just to take the unsupported weight off the joint.
Frank
They flew, I took up naturism
scanner
Post by scanner » Mon Oct 28, 2013 12:38 pm
Diplomat wrote:It's almost a certainty with this design that the join will fail where the pipe is welded into the back box. There is so much weight applied at this point, with some twist for good measure. The twist becomes apparent when you try inserting a piece of mating diameter tubing to try and make a temporary fix.
Frank
Yes it is a totally pathetic bit of design.
I would never fit an original (or pattern) rear box again - it is also about half a hundredweight of unneccesary ballast.
Gasy
Post by Gasy » Mon Oct 28, 2013 1:13 pm
Be a boy racer and put a cherry bomb on it
scanner
Post by scanner » Mon Oct 28, 2013 2:34 pm
Gasy wrote:Be a boy racer and put a cherry bomb on it
No need to pay that much, a straight piece of pipe will do.
tigger
Post by tigger » Fri Nov 01, 2013 11:17 am
You'll be fine. I drove for hundreds of miles with no back box on my Bongo before getting it sorted. You've got a turbo-diesel - so the less back pressure from the exhaust system the better. You might notice slightly more noise under full throttle, and a slightly better throttle response. Other than that, no problems - drive on!
Dom
cmm303
Post by cmm303 » Fri Nov 01, 2013 4:31 pm
tigger wrote:...You might notice slightly more noise under full throttle, ...
Mine was a very noticeably noisier when just the tailpipe dropped off.
Chris with BertieB
