Bongo Not starting Glowplugs ?
Posted: Thu Oct 10, 2013 12:43 pm
by bongobaz
Bongo not starting in cold, put new battery on, it was ok for a while
but again now in this cold spell,it turns over but no start. Suspect glowplugs any tips would be appreciated.
Re: Bongo Not starting Glowplugs ?
Posted: Thu Oct 10, 2013 2:12 pm
by tallbongo
Any other symptoms? Lumpy idling when it was cold?
Because it was initially fine with the new battery it sounds more like your battery isn't charging very well, although clearly it isn't completely flat as it turns over the starter motor. What voltage is the battery reading?
Posted: Thu Oct 10, 2013 3:46 pm
by wonkanoby
starts in warm then not once nippy is usually the glow plugs
Posted: Thu Oct 10, 2013 4:00 pm
by bongobaz
It's reading 12.56 after an overnight charge still not firing thanks for reply. No other symptoms it was cold then too, New battery seemed easiest option as the other was on when i bought it 5 Years ago.
Posted: Thu Oct 10, 2013 5:58 pm
by briwy
Check you have got power going to the glowplug rail rail when it's cold baz.
Posted: Thu Oct 10, 2013 6:56 pm
And check voltage to plugs when starter motor is turning - that might help identify tired battery?
Posted: Thu Oct 10, 2013 7:25 pm
by hijimhere
Make sure all consumers are off then check for any current leakage with a meter --- after that check your alternator output. Is the glow plug light coming on when you are ignition live? How long is it staying on before you crank? The battery could do with a drop test just to eliminate it. But it is sound like glow plug relay or plugs. Plugs are best all replaced at the same time. Can some one point the direction of the Glow plug relay?
Posted: Thu Oct 10, 2013 7:34 pm
hijimhere wrote:Make sure all consumers are off then check for any current leakage with a meter --- after that check your alternator output. Is the glow plug light coming on when you are ignition live? How long is it staying on before you crank? The battery could do with a drop test just to eliminate it. But it is sound like glow plug relay or plugs. Plugs are best all replaced at the same time. Can some one point the direction of the Glow plug relay?
I agree. Good advice
Posted: Thu Oct 10, 2013 9:30 pm
by tallbongo
Assuming the battery is not at fault, and the glow plug lights are coming on, check the the supply feed from the battery terminal to the relay is connected. I've seen this left unconnected after a battery change, resulting in a non-starter van.
If you need to check further, glow plug relay is under bonnet on driver's side wing if I recall correctly.
