what oil?
Posted: Tue Oct 08, 2013 12:24 pm
by hwyaden
what type of oil should i be using? i've got loads of 5/40 left over from my last car which drunk the stuff - can i use this in bongo or do i need a thicker one?
Re: what oil?
Posted: Tue Oct 08, 2013 12:48 pm
by Simon Jones
Depends what engine you have
Re: what oil?
Posted: Tue Oct 08, 2013 1:21 pm
by hwyaden
it's a 2.5 diesel :)
Re: what oil?
Posted: Tue Oct 08, 2013 1:49 pm
by rita
Also depend on the spec of the oil.
Re: what oil?
Posted: Tue Oct 08, 2013 3:39 pm
by hwyaden
it says: 5W40 Fully Synthetic Engine Oil :)
Re: what oil?
Posted: Tue Oct 08, 2013 3:42 pm
by scanner
Should be OK, some say 5W/30 others use 5W/40 quite happilly.
Re: what oil?
Posted: Tue Oct 08, 2013 4:27 pm
by hwyaden
i had no idea there were so many different types :shock:
Re: what oil?
Posted: Tue Oct 08, 2013 4:36 pm
by Simon Jones
Check the can says its compatible with turbo diesels. Chances are if its modern spec it should be ok.
Re: what oil?
Posted: Tue Oct 08, 2013 7:21 pm
by David Edwards
Lidls oil is superb and was recommended to me years ago by an old well time served diesel grease monkey,lol...trouble is it is like unicorn turd, soon as it comes in it is gone...the local garages grab it.
Re: what oil?
Posted: Tue Oct 08, 2013 8:32 pm
by hwyaden
:lol:
Re: what oil?
Posted: Tue Oct 08, 2013 11:09 pm
by Northern Bongolow
you need one suitable for turbo diesel WITH EGR if yours hasnt been blanked off. this keeps the engine clean as it suspends the carbon put into engine by the egr system.
Re: what oil?
Posted: Tue Oct 08, 2013 11:29 pm
by hwyaden
what's egr?
Re: what oil?
Posted: Tue Oct 08, 2013 11:57 pm
by Bob
Exhaust Gas Recurculation. A search will reveal all, and Allan's, Plymouth sells blanking plates for about twelve quid. :wink:
Good mod in my book. :)
Re: what oil?
Posted: Wed Oct 09, 2013 1:23 am
by Jaws
hwyaden wrote:what type of oil should i be using? i've got loads of 5/40 left over from my last car which drunk the stuff - can i use this in bongo or do i need a thicker one?
This will be fine for your Bongo. 5w30 is the OEM spec but unless you live somewhere really cold it will not be a problem. Just make sure you change it regularly!
Re: what oil?
Posted: Wed Oct 09, 2013 12:29 pm
by hwyaden
wow, i'm learning new stuff every day with this van!! my old toyotas seem simple in comparison :D
