mellon man
Post
by mellon man » Wed Oct 02, 2013 3:20 pm
I NEED TO KNOW the best place to fit a electrical hook input socket on my Bongo.
I notice at the back of the rear right hand side wheel arch looks a good level area noticed is double skinned so is there enough depth for a socket
I hope Please someone can you advise me before I start to drill and cut the side of my van
Post
by Muzorewa » Wed Oct 02, 2013 3:29 pm
mellon man
Post
by mellon man » Wed Oct 02, 2013 5:16 pm
Thanks Got it "Supreme Being"
Now any suggestions (clean ones) where I can put RCD'S & plug sockets
briwy
Post
by briwy » Wed Oct 02, 2013 5:22 pm
The other side works OK as well, definitely not double skinned here, depends where your conversion is. This was for a factory Cube Kitchen.
Measure it well before cutting and seal it with silicone sealer between the bodywork and the socket body.
mellon man
Post
by mellon man » Wed Oct 02, 2013 5:48 pm
Cheers briwy - mine not as big as those (ohh Matron) mines square
so wont need such a big hole but more depth (to many innuendos I'd better stop now)
Diplomat
Post
by Diplomat » Wed Oct 02, 2013 6:56 pm
I would run the cable in through the driver's window and drape it across the steering wheel.
Anywhere round the back could result in an attempt to drive away while still connected!
Frank
They flew, I took up naturism
mellon man
Post
by mellon man » Wed Oct 02, 2013 7:01 pm
Cheers good call
wilnx005
- Bongonaut
Post
by wilnx005 » Wed Oct 02, 2013 7:56 pm
Has anyone ever tried popping one of these T4 dummy fog lights in their rear bumper?
http://www.ebay.co.uk/itm/VW-T4-TRANSPO ... 1e64fa5d47
I need to change my old rubbish fog light and thought one of these with a hook up behind it may work, has anyone tried it? - my friend has a T4 with his hook up behind it. Looks very tidy and no need for cutting scary holes
salexander
- Bongonaut
Post
by salexander » Thu Oct 03, 2013 10:56 am
If I was fitting a new hookup socket i'd be looking at fitting it to the rear bumper. Much easier to cut the plastic and no worries about sealing metal bodywork and rust.
mellon man
Post
by mellon man » Thu Oct 03, 2013 2:12 pm
How would you water proof the back of socket where you fit the internal power leads ?
Is there a safe water proof input socket you can recommend ??
mikeWalsall
Post
by mikeWalsall » Thu Oct 03, 2013 3:20 pm
Mine is a 'professional' conversion .. they have used 1" god awful corrugated trunking ..
Dunno about water proof but it gives a very amateurish look ...
Mind you .. I say professional a bit tongue in cheek .. when I pulled the panel back to get to wax oil I sliced my finger open .. when they cut the 'patch' out for the 240v inlet .. they had left the razor sharp oblong bit of scrap in the bottom of the inner wheel arch ..!!
mellon man
Post
by mellon man » Thu Oct 03, 2013 3:55 pm
Yes think will bring mine in that way Mike, picture does not show where cable goes looks like its it go into some sort of box ?
mikeWalsall
Post
by mikeWalsall » Thu Oct 03, 2013 4:03 pm
The RCD box behind the rear seat is just as amateurish and takes up valuable space ..
The front of the panel is also difficult to get to ..as it involves 'grovelling' around on your belly ..
mellon man
Post
by mellon man » Thu Oct 03, 2013 8:26 pm
Right Dave, yes not the best use of space, but impressive control pad though
I was just going to fit an isolator with a twin RCD socket and may be a in line with a 13amp or lower fuse box (if enough room as I already have these spare so save me money)
Will that be safe enough
