http://www.ebay.co.uk/itm/Toad-Alarm-A5 ... 0700504990
Has anyone had any experience of fitting one , reading the manual it seems fairly straightforward as long as I can identify the wiring on the bongo, any advice would be welcome
Moderator: Ian
elbee wrote:Thanks For the advice guys, just for your info I'm pretty much ok with both low voltage and mains electrical wiring, being an electrician and AV electronics engineer,I guess I was just being lazy in asking for the best circuit. I've just fitted the willinton split charging kit, works a treat by the way and fitted a new head unit and repaired both door looms.
Depends on the installer! if they know bongo's there are several methods to immobilise the vehicle other that the fuel cut off solenoid. As mentioned in a previous post, a self fitted alarm is usually much easier to bypass than a professionally fitted unit!Simon Jones wrote:Fitting an immobiliser is likely to differ depending on whether you have a diesel or petrol engine. Petrol vehicles have electric fuel pump & ignition systems which can be interrupted, whereas the diesel only really has the fuel cut off solenoid. Alternatively, fit it inline with the power to the starter motor solenoid, but that would not prevent a manual vehicle being bump started.
