leisure battery
Posted: Thu Sep 12, 2013 1:34 pm
by graham8299
recommendations for new leisure battery, any advice welcome -- its for a 1995 2.5 turbo diesel 4wd. cheers
Re: leisure battery
Posted: Thu Sep 12, 2013 9:29 pm
The largest size that fits your tray and doesn't get hit by the bonnet!
Not all trays are the same size.
Re: leisure battery
Posted: Fri Sep 13, 2013 7:52 am
by Dr Fingers
V pleased with this
Xplorer low height 110 amp hour leisure battery for £79.99 including VAT & delivery which is only 175 mm tall.
http://www.alpha-batteries.co.uk/
following Willintons suggestion..
Derek
Re: leisure battery
Posted: Fri Sep 13, 2013 12:23 pm
by hijimhere
I have worrying bolt heads on the surface of the battery tray -- I need an idea of what folks used under the battery that has worked please!
one of the batteries (I have the norther duel batteries) which could be OE is almost at a height where closing the bonnet could be a problem. I may have about 5/7 mm only to play with.
Re: leisure battery
Posted: Fri Sep 13, 2013 12:29 pm
by francophile1947
hijimhere wrote: one of the batteries (I have the norther duel batteries) which could be OE is almost at a height where closing the bonnet could be a problem. I may have about 5/7 mm only to play with.
I had the same problem with my old winter model. I couldn't get a leisure battery, locally, to fit, without hitting the bonnet :( I ended up using a normal battery and fitting an isolating switch to separate the batteries when not running - obviously having used Pippin's instructions to get most things to work from the second, isolated battery.
Re: leisure battery
Posted: Fri Sep 13, 2013 1:30 pm
by Dr Fingers
hijimhere wrote:I have worrying bolt heads on the surface of the battery tray -- I need an idea of what folks used under the battery that has worked please!
The Willinton kit I rec'd comes with a battery tray, everything fits in just perfect.
Derek
