Hi wise people,
Before my mot last week I changed the the bulbs
I had in my bongo back to the standard ones.
Just in case. Now the bulbs I put in are stuck
And aren't working. What's the best way to get them
Out, and to get them up and running again.
Thanks in advance.
Side lights
- mikeWalsall
Re: Side lights
Lube them with some WD40 .. check the bulb holder contacts are clean when fitting new bulbs ..
Re: Side lights
Thanks I will try that. Now my left indicator is flashing too fast. What goes on?
Re: Side lights
one of the left indicators isnt flashing so the other flashes faster..
Either that or you have led ones in which have inadequate resistance
http://WWW.NEWACRECARS.COM IMPORTERS
Re: Side lights
Sorted. You were right. The left indicator was
Off. Patched it up again now.
- mikeWalsall
Re: Side lights
Also .. as the 'tell tale' light on dashboard would be flashing a lot faster ... it acts as a warning that one of the Indies is not working..
Re: Side lights
Yes it was clicking like mad. All good now though.
