Auto box 'sluggish' 2L petrol
Posted: Fri Aug 09, 2013 1:09 pm
Hi though I would flag this one, had a bit of a poke around search, but not really any similarities / other posts.
The van is generally running great 98% of the time, but recently I have noticed that when the engine is cold there doesn't appear to be any 'umph' or pick up in 2nd. No matter how much you put your foot down, and in fact it picks up better if you keep a light foot. The problem is only really noticeable on inclines putting away from junctions etc. I have checked the levels of the auto box fluid (which was replaced a couple of years ago (about 12,000 miles back) which are fine. The problem appears to go once the van is warmed up, and continues to run fine. No noticeable loss of power at higher speeds etc, and the engine is running nicely (just been serviced).
Any ideas folks?.......
And before anybody pipes up..... yes I know the 2L is 'under powered' at the best of times.
but then so am I, so its kind of a good fit.
cheers
David.
cheers
David.
