Belts Alternator & aircon
Posted: Wed Aug 07, 2013 10:04 am
by hijimhere
Bought belts which were listed for 2.5 td - supplied with toothed belts which appear to long for alternator. Also air con is toothed but not yet determined if length is ok. Belts on engine are bog standard V belts. I had the new belts for a while before looking to change & having a comparison with whats fitted. Are the V's being displaced by toothed versions? I'd much prefer to stick with V if I can?
Re: Belts Alternator & aircon
Posted: Wed Aug 07, 2013 12:31 pm
by Darkstar
I might be wrong here so correct me anyone.
I think the belt sizes are: Aircon belt size; 1000 x 13mm, Alternator/ waterpump - 1090 x 13mm.
The toothed belts do not require as much tension to grip the pulleys than the standard v belts, and so dont put as much strain on the bearings.
Dont know whether the toothed belts have the same lifespan as V belts though, i suspect not.
I was also advised sometime ago that if you have a two belt pulley system like our alternator setup that you should ask for a matched pair of belts, (having been cut of the production belt Tube sequencially and packaged together). you can buy paired sets for some Motor factors but normally i get a blank look when i ask. this is to reduce slight variations in belt diameter.
when you fit un-matched belts you can sometimes get a little bit of play in one of them, which look a lot when the engine is running.
Posted: Wed Aug 07, 2013 10:48 pm
by hijimhere
I ordered the belts through our leader 2x for alternator and 1 x air con -- all are toothed. will look to install tomorrow.
Posted: Wed Aug 07, 2013 10:51 pm
by Simon Jones
If they've come from the club shop, they'll be the right size
