Front Fans Stopped Working
Posted: Thu May 23, 2013 5:47 pm
by David Edwards
Anyone have any ideas why, the air con panel lights up and the indicator bars move as normal, all the controls are ok, just nothing from the fan, dont even know where it is to thump it,lol, has anyone gone thru this, any causes and remedies etc, cheers folks.
Re: Front Fans Stopped Working
Posted: Thu May 23, 2013 6:52 pm
by wonkanoby
usually a blown transistor means you have to set it on full
if nothing at all i would look at fuses first
Posted: Fri May 24, 2013 4:12 pm
by David Edwards
Nope, checked the fuse (No. 16) all ok, dont know where the fan is, I suspect knowing the bongo it is somewhere really awkward to get to, especially with my knackered back, does anyone know if there is sheet or info on checks to do etc please.
Posted: Fri May 24, 2013 4:48 pm
by helen&tony
David...
Members area, fact sheet entitled heater repair. It details how to repair bushes, but in terms of what you want, it shows how to get there!
Posted: Fri May 24, 2013 6:37 pm
by thedogsbollox
You sure the fan is actually not working as a common problem is the aircon matrix getting gummed up with debris. The fan works but can't blow into the cab. Easy fix if this is the case.
Posted: Fri May 24, 2013 7:03 pm
by David Edwards
Helen thanks sweetie, went out and removed inlet cowling, fiddled with connector and hey presto, fans once again working like the clappers, would never have thought of it if you hadnt said about the sheet, awesome,lol.
Posted: Fri May 24, 2013 7:33 pm
by helen&tony
Hi David
It's worth stripping the lot out until you can see the aircon matrix, and give it a good tooth-brushing, and if you have a compressor, give it a blast through, or borrow one . You'd be surprised how much better they work after!...if not, get a good vac. cleaner on it!
Posted: Fri May 24, 2013 8:15 pm
by David Edwards
yep will do tomoz vacuum it right out, also gave it a good squirt of wd 40 type stuff too.
Posted: Fri May 24, 2013 8:58 pm
by Simon Jones
If you get the whole fan housing off, it reveals the matrix Helen mentioned. You'll find a lot of dead things squished in the matrix, but be quite gentle when brushing or vacuuming it put as the fins are quite fragile.
The heatsink fins on the resistor / transistor pack can just be seen poking into the air flow at the top:
