				Hose blown!
				Posted: Sun May 12, 2013 8:39 pm
				by jimpearceuk
				After 2 years of happy Bongoing I had my first major coolant issue last night on the M4, first thing  I know Haydn Low Coolant Alarm is beeping at me... So Haydn another notch for the engine saved post.
After recovery I've had a look, the hose, a thick one under the drivers seat top right up next to the right of the EGR steel pipe, anyone knows which one this is please? If that's to vague I can post a pic?
I've seen these silicon packs of quite a few the blue coloured ones, should I get them? Should I be replacing all the hoses? If not which ones should I change?
Thanks Jim
				Re: Hose blown!
				Posted: Sun May 12, 2013 11:13 pm
				by briwy
				Sounds like the same one we had go a few weeks back
It's the main hose that goes to the steel pipe leading back to the radiator.
Have a look at the Lush projects pages depending on which model Bongo you have.
Got ours from Ian at the shop.
I changed all the main hoses on the basis that it is 12 years old and if one has gone it's likely the others are ready.
				Re: Hose blown!
				Posted: Mon May 13, 2013 9:04 am
				by wonkanoby
				http://www.igmaynard.co.uk/bongo/forum/ ... ilit=norma
be sure to do pipe runs across starter moter
then look at rest
				Re: Hose blown!
				Posted: Mon May 13, 2013 10:32 am
				by jimpearceuk
				Thanks Briwy. Will look at Lush.
Out of interest roughly how many did you replace? About 5?
Thanks Jim
				Re: Hose blown!
				Posted: Mon May 13, 2013 1:21 pm
				by helen&tony
My gut feeling is that if one goes, you need to raid the piggy bank and get the rest done for peace of mind, and change the stat and water-pump...radiator too if funds permit....I think you can then put your feet up and put most of the rest of the Bongo problems behind you....it'll only be the odd joints and rubbers to cause minor concern then!
				Re: Hose blown!
				Posted: Mon May 13, 2013 4:38 pm
				by briwy
				Yes, did the 5 main ones Jim.
				Re: Hose blown!
				Posted: Mon May 13, 2013 6:02 pm
				by yorkee
				hi, Bought my Bongo and it had the 5 main hoses replaced. Sourced the other 12 and all clips from my local mazda dealer using the part numbers from Lushprojects. If the number is available on the drawing then the mazda dealer can usually get it.  Some are available in their europe depot others come from Japan so it is best to plan ahead if possible and get the parts before you start the job.
				Re: Hose blown!
				Posted: Mon May 13, 2013 10:29 pm
				by Northern Bongolow
				Re: Hose blown!
				Posted: Thu May 16, 2013 6:41 pm
				by jimpearceuk
				Thanks all
Doing the 5 for now.
Cheers Jim
