Hi anybody up there in the frozen north,does anyone know of a Bongo friendly Garage in or around the Whitehaven Area.Any suggestions will be gratefully accepted.I have a friend with a sick Bongo that needs a bit of help.
Cheers davetheclockman (southwest branch).
Bongo Friendly Garages
Moderator: Muzorewa
davetheclockman
- Apprentice Bongonaut
Re: Bongo Friendly Garages
Wheel quick in wigan are very good
What kind of help. Is it well enough to travel ant distance. There's no reason why someone local and conscientious should be capable, with a little support from this forum.
davetheclockman
Hi ,Thanks for replies,the Bongo is stuck in a garage in Whitehaven at the moment with a suspected Head Gasket or worse i believe.Will have to be transported away i think,so need a garage reasonably close to there.Only a tyre fitting garage at the moment and a bit too technical for them i think.Trying to sort this out third hand,so allways difficult,but any suggestions will be gratefully accepted and passed on.
Cheers davetheclockman.
pm sent.
