Astra Headlights
Posted: Wed Apr 24, 2013 2:35 pm
by stuc
Hi, does anyone know which year astra lights apparaently fit into the bongo, also do they fit new shape or old shape.
Has anyone got any pics?
Re: Astra Headlights
Posted: Wed Apr 24, 2013 3:36 pm
by mikexgough
Been a Thread on here about Astra lights.... think if I remember they are from the Mk3 Astra F
Posted: Wed Apr 24, 2013 5:58 pm
by helen&tony
Astra Mk3 - they fit the old shape. I have them fitted. I had an Astra and the Bongo sitting on the drive some years back...guess what?...I found they fitted... hence the rush on Astra lights
Posted: Thu Apr 25, 2013 12:53 pm
by stuc
Hi cheers, I did find the thread, but they wont fit mine, I found a german site selling really nice light units for various cars and i thought I may have been able to fit some, but no.
Posted: Sat Apr 27, 2013 8:38 pm
by David Edwards
any piccies of the astra lights in bongo
Posted: Sun Apr 28, 2013 4:39 am
by helen&tony
Hi David
Here:
Posted: Sun Apr 28, 2013 8:22 am
by Diplomat
They already look brighter than Bongo lamps, without even being switched on!
Frank
Posted: Sun Apr 28, 2013 9:55 am
by stuc
They look really good, nice fit and as above they just look brighter and cleaner.
Posted: Sun Apr 28, 2013 10:11 am
by helen&tony
Posted: Sun Apr 28, 2013 10:25 am
Aye. Fact is nothing works better than a pair of beefy spotlights wired to come on with main beam (i think daveblueozzie has ones with a dipped beam also). You need a fender defender bar to mount them on mind you.
Posted: Sun Apr 28, 2013 11:30 am
by helen&tony
Hi Mike...
Welllllll....one just HAS to have some (ahem) legal spotlights on one's FDBs, doesn't one....
....apart from the fact that if I ever venture forth at night here, you have to have a set of lamps brighter than the other car's headlights, as the oncoming driver is more than likely as drunk as a skunk after 3.00 PM and can't find the dipswitch!....they're good at finding grass verges and ditches to drive on / in , though...
especially with your lights coming towards them
Posted: Sat May 04, 2013 7:46 am
by cheffy34
Love em H&T ! want some are they diffacult to line up? what needs making up to make em fit?
dar
Posted: Sat May 04, 2013 9:33 am
by helen&tony
Cheffy
Not easy to fit, but I dismembered the old Bongo lights, and glassed the mounts from the old lights onto the new Astra ones....I took a mould of the old indicators, and from the mould I've formed a plug to wrap heated perspex on to make clear indicators...still not got around to that, as I have to find the right grade of perspex yet!...The top of the new lights is a bit low, so I filled the gap with some amber LEDs to act as auxiliary indicators. The grill is the Mazda original with the centre cut out and an inch or two shaved off the edges outside. and the inner edge built up with plastic filler, and the back is filled with foam and glassed before bonding the mesh on. I still have to neaten up the headlights under the bonnet. The polished alloy buttons are for grill removal
The photo is an older one, as I now have a set of Phillips Luxeon Rebel DRL s recessed into the panel under the headlights, and I've modded them to dim when the sidelights go on, which are Angel Eye rings round the headlamps
There is a fair old bit of wiring to add to the Bongo for the lamps, and that is still to be tidied, but I've already started another wee
project on the Bongo...
If you want more details, just ask
