liesure battery not charging
Posted: Sun Apr 07, 2013 2:11 pm
by andyman
purchased our bongo late last year, all in working order. took in to have brake pads and fluid changed. couple of days later noticed no radio, no rear interior light and guess no fridge
have checked all fuses and cant find any blown. liesure battery totally flat with no charge coming to it [a friend put a meter on it) Please help where do i look next?????? need my music and chilled beer! Thanks
Andy
Re: liesure battery not charging
Posted: Sun Apr 07, 2013 3:56 pm
by wonkanoby
check fuses and earth
Posted: Sun Apr 07, 2013 4:18 pm
by not so old
Did you leave your fridge turned on and drained the battery?
Posted: Sun Apr 07, 2013 6:19 pm
There should be TWO fuses in the cable between the S/B and the L/B as well as the relay (normally in-line fuse holders), check both fuses and if one has gone replace BOTH!
What type of charging system do you have for the L/B is it a Willinton kit, or some other Voltage Sensitive Relay type, or is controlled by the Ignition switch, if you know the type then you can check the relay for operation (hand on the relay and you will feel it click), if its a VSR type then get the rev's up on the alternator and you should feel it click, otherwise check when the Ignition is turned ON.
