Relay ticking
Posted: Mon Mar 04, 2013 3:25 pm
Hi all, since installing a new touch screen stereo just after Christmas http://www.ebay.co.uk/itm/Erisin-ES996G ... 0925421320 a few strange things have happened. (This is wired to the LB and charged from the Willinton kit)
Occasionally when starting from cold, I get the feeling that the crank battery is about to fail and then all of a sudden she spins away and fires.
Recently after a twenty mile trip I sat for several minutes playing with the built in Sat Nav settings to navigate back home and when I turned the key it just grunted and wouldn’t turn over so I had to get a jump start off from someone.
I’ve had a Willinton kit fitted for about 18 months and a new 110 ah LB only last September and the LB has not been used whilst parked up for camping purposes since then. Since last September, I have often checked the charge state of the LB by looking at the built in green indicator and it has always been green but over the last month or so it shows nothing or just ‘clear’
I decided to check the SB leads for tightness and whilst the bonnet was up I tried the starter and listening for the usual click from the Willinton, I was surprised to hear the relay click several times before settling down. I then got someone else to turn the key and I could see the green light on the Willinton relay flashing on and off with every click. When I turn the engine off, there is usual single click after a few seconds.
Does anybody know what could be happening please?
