				V6 Distributor
				Posted: Thu Feb 21, 2013 2:19 pm
				by Bainsy
				Excuse my ignorance but never having taken off the distributor cap on my 1999 new shape V6 I have no idea what is inside. Is it a traditional rotor arm and points which need to be regularly changed?
				Re: V6 Distributor
				Posted: Thu Feb 21, 2013 2:42 pm
				Re: V6 Distributor
				Posted: Thu Feb 21, 2013 2:51 pm
				by mikeWalsall
				Being an electronic ignition system .. rotor yes .. (Kettering) points no ..
				Re: V6 Distributor
				Posted: Thu Feb 21, 2013 2:58 pm
				by Simon Jones
				Cap:
Rotor (old and new):
All the bits are available from the club shop, although the rubber seal under the cap may not be a stock item.
				Re: V6 Distributor
				Posted: Thu Feb 21, 2013 3:07 pm
				by Bainsy
				Thanks guys. How often should the cap and rotor arm be changed?
				Re: V6 Distributor
				Posted: Thu Feb 21, 2013 3:22 pm
				Not sure that there is a specified period as such, when you have problems inspect and replace if required.
				Re: V6 Distributor
				Posted: Thu Feb 21, 2013 3:30 pm
				by Simon Jones
				Never noticed an official replacement schedule, but if the contacts in the cap are badly marked then it's worth replacing it and the rotor arm as a pair. Note that there is a special rough coating on the tip of the arm which means you can't just fettle up the old one with a piece of emery cloth like you would on something like the BMC A-series engines. I've just replaced both, all 7 leads and the plugs prior to
LPG conversion and it didn't make any difference to the performance of the engine, but it was worth it for peace of mind
				Re: V6 Distributor
				Posted: Thu Feb 21, 2013 3:40 pm
				by mikeWalsall
				On most cars I have had from I have always changed the dizzy cap .. leads .. rotor .. points / condenser etc: .. as a matter of routine .. just be aware the Bongo prices for 'routine' parts are not exactly cheap .. and not readily available on a Sunday from your local motor spares shop ..
My Bongo is 15 years old .. well past replacements .. recently the tick over started to get rough / lumpy .. I looked under the lid thinking to remove the dizzy cap / rotor and clean up the electrodes .. with the wet weather and the hassle involved .. I passed on the job so I  just changed the 6 (easy to source / get to) spark plugs..
With running on LPG ..  I closed the plugs gap to 0.1mm .. that alone made a remarkable difference .. so I would think removing the dizzy .. cleaning it .. new cap / leads and  strobeing up would make an even better improvement ..
