leaking fluid
Posted: Tue Feb 19, 2013 11:45 pm
by Nutcase
Hi guys, just bought a anew fuel filter off ebay for my 2.5 td freeda and had a look under drivers door to see where she fits an bingo there it is.
Anyway justnoticed that the hydraulic lever that goes into the 'gearbox'??? that is on the o/s ofthe engine appearsto be leeking, should I be worried, is it an easy fix.
Many thanks
Re: leaking fluid
Posted: Wed Feb 20, 2013 2:14 pm
by teenmal
Hi Nutcase,what kind of box?
Re: leaking fluid
Posted: Wed Feb 20, 2013 2:53 pm
by Simon Jones
The only lever I can think that's fitted on an auto box is the cable operated one that comes from the gear selector.
Re: leaking fluid
Posted: Wed Feb 20, 2013 5:21 pm
by Nutcase
Hi its a. Manual Ford Freeda and is located about half way up what I think is the gear box which is connected to a flexible hose that runs the o/s to a connection, ill have another look tonight when I get home from work.
Re: leaking fluid
Posted: Wed Feb 20, 2013 5:34 pm
by teenmal
Sounds like it might be the slave cylinder that you are looking at.?
Press the clutch pedal and see if it moves.
Re: leaking fluid
Posted: Wed Feb 20, 2013 8:12 pm
by Darkstar
Re: leaking fluid
Posted: Wed Feb 20, 2013 9:34 pm
by Nutcase
Yes it's the slave cylinder, should I be worried, it's not flowing out just the odd drips by the look at the drive.
What should I do?
Re: leaking fluid
Posted: Wed Feb 20, 2013 9:45 pm
by the laird
Keep it topped up but get it sorted you can get a repair kit .you will eventually loose clutch pressure and won't get gears
Re: leaking fluid
Posted: Wed Feb 20, 2013 9:51 pm
by Nutcase
Cheers fella, where would I get a repair kit from, an how much are they.
I've just looked on ebay, roughly £50, are they the same for auto/manual.
Re: leaking fluid
Posted: Wed Feb 20, 2013 10:01 pm
by the laird
Autos don't have one.any reputable factor but try bongo fury shop first,fifty quid seems a bit steep!
Re: leaking fluid
Posted: Wed Feb 20, 2013 10:30 pm
by Nutcase
Nice one, I meant £50 ish for a new one or is that expensive?
Re: leaking fluid
Posted: Wed Feb 20, 2013 10:33 pm
by the laird
Motor factors will sell slave cylinder repair kits .you get seals,spring? If fitted and dust cover.(new poss twenty quid)but that's a guess
Hope this helps
Re: leaking fluid
Posted: Wed Feb 20, 2013 10:38 pm
by Northern Bongolow
Re: leaking fluid
Posted: Wed Feb 20, 2013 11:39 pm
by Nutcase
Many thanks
