Lpg inspection
- Tribal Elder
Lpg inspection
When I checked if I was on the lpg register I offered my bongo up for inspection, I've been selected and he's coming on Tuesday, mine was fitted by David Connelan who is said to be excellent, so I don't expect any problems.
I've read a couple of posts that say they don't inspect much, however the inspector sounded very clued up on the phone so will see how it goes, more for "peace of mind" i suppose.
"Today's rain is tomorrow's Whisky"
- mikeWalsall
Re: Lpg inspection
I had mine 'inspected' before Christmas .. the guy did not find any problems ...
Strangely last week I had another phone call from LPG UK ... could they send some one round to inspect the LPG conversion ... he was bit bemused when I told him it had been done a couple of months back ...!!
Apparently the 'inspector' ... (I forget his name .. I remember he had a supercharged (Kompressor) Mercedes) .. had not submitted the report into the office ..
- Tribal Elder
Re: Lpg inspection
I think I saw your post at the time Mike, and it stuck in my mind that you were surprised at how little he actually inspected.
He is due around 2pm today so I will see how it goes,
Jim....
Jim....
- mikeWalsall
Re: Lpg inspection
I was surprised how quick the 'job' was done ...
I suppose I expected an MOT type of inspection with the bus up on ramps .. the guy underneath pulling and tugging at pipes and the like .. engine running .. probe up the exhaust pipe etc:..
But no ... it was just a five minute visual ... the guy did not even seem the chatty .. stop for a coffee kind either .. job done .. in his Merc. and away !!
But I am glad I had it done .. at least with UKLPG following jobs through by checking independent Autogas fitters .. proves they are an ethical organisation .
- Tribal Elder
Re: Lpg inspection
Exactly as you said Mike, no tea or coffee required, (although he did explain he had a bit of a drive ahead of him), 100%visual 5 minute inspection, he was happy with the job, I mentioned my bongo was cutting out on lpg whilst cold he then gave me the contact number of a Guy at Scotlandwell (Kinross) who is the top man in the area for setting up Romano systems, so I found him quite helpful.
- Tribal Elder
Re: Lpg inspection
Visited the guy at Scotlandwell near Kinross, he gave my bongo the once over on my lpg system, did not like where the valve unit was mounted on side of the tank,(it's right behind the rear wheel) as the rear wheel throws crap all over it, he advised me to spray it as soon as possible with clear wax oil. He also fitted some rubber sleeving to my plastic gas pipes, (he always fits copper pipes to his conversion) as the outer core of the pipe was getting roughed up by a couple of engine brackets. He adjusted my lub-oil system to 10 drops per min, I had noticed that it was still almost full, and had not required topping up since I bought the bongo (3000 miles and hardly used a drop), confirmed it was a good neat conversion apart from the valve mount position on the tank.
Re: Lpg inspection
Jim the Box wrote:Visited the guy at Scotlandwell near Kinross, he gave my bongo the once over on my lpg system, did not like where the valve unit was mounted on side of the tank,(it's right behind the rear wheel) as the rear wheel throws crap all over it, he advised me to spray it as soon as possible with clear wax oil. He also fitted some rubber sleeving to my plastic gas pipes, (he always fits copper pipes to his conversion) as the outer core of the pipe was getting roughed up by a couple of engine brackets. He adjusted my lub-oil system to 10 drops per min, I had noticed that it was still almost full, and had not required topping up since I bought the bongo (3000 miles and hardly used a drop), confirmed it was a good neat conversion apart from the valve mount position on the tank.
What was the "cutting out on lpg whilst cold " problem.(cure)
- Tribal Elder
Re: Lpg inspection
Yep! it's just a case of him adjusting (with his laptop), the switch-over temp, setting it a few degrees higher to allow for the cold weather at this time of year. He said the sensors can be out + or - a few degrees and need sometimes need to adjusted slightly during cold snaps especially if your lpg has been fitted and set up in the summer.
- mikeWalsall
Re: Lpg inspection
My Bongo takes twice as long to switch over to gas than my Toyota .. but they both switch over seamlessly ..
Although the temperature gauge reads 'normal' and you can feel the heater .. when first getting into traffic, the Bongo 'hunts' a bit .. but after say another five minutes it is fine ..
I know that my Bongo could do with a new dizzy cap .. rotor and plug leads .. as I had already bought 6 new NGK plugs for less than £10 off eBay I thought I would fit them any way ..
Only an easy five minute job to remove the old ones .. to find they looked brand new .. electrodes square .. the porcelain still shining white ..
The only problem was they had been overtightened ..and the threads appeared to be 'pulled' and slightly distorted .. being into alloy heads that is not good .... so rather than re fitting them .. I closed the gaps on the new plugs down to 0.imm .. and fitted those instead ..
The change is unbelievable .. engine still starts fine .. but now ticks over like a sewing machine, with none of the previous 'iffy' tick, over with the revs raising / dropping .. when it seemed likely to stall ..
BUT .. the 'lumpy' running when first switching over to gas when in traffic, still needs to be tweaked out ..
- Tribal Elder
Re: Lpg inspection
Mike,
He also said people were being given details of software so as they could make their own adjustments to their lpg set ups.
He's has had several people in for repair who have tried to make adjustments with disasterous results, so I think i'll just stick to using the experts.
- mikeWalsall
Re: Lpg inspection
The guy who fitted the LPG to my Toyota is sound guy .. and still in business .. I will get him to service the system and tweak it as required ..
http://www.nationwidelpg.com/
A few pics of my Estima (Previa) in his No3 gallery ..
- The Great Pretender
Re: Lpg inspection
Reprogramming an ecu isn’t difficult if you understand the information it is telling you, you then look at where your adjustments are taking you………….Simples…………If you don’t understand it ………LEAVE IT ALONE…………..Jim the Box wrote:Mike,
To infinity and beyond
Re: Lpg inspection
That's strange,I always thought that the change over from petrol to LPG was controlled by engine temperature not weather temperature.You live and learn.Jim the Box wrote:Yep! it's just a case of him adjusting (with his laptop), the switch-over temp, setting it a few degrees higher to allow for the cold weather at this time of year. He said the sensors can be out + or - a few degrees and need sometimes need to adjusted slightly during cold snaps especially if your lpg has been fitted and set up in the summer.
- mikeWalsall
Re: Lpg inspection
I find in warmer weather .. my engine warms up more quickly than in freezing weather .. and switches over to gas quicker in summer than winter.
- Tribal Elder
Re: Lpg inspection
That's strange,I always thought that the change over from petrol to LPG was controlled by engine temperature not weather temperature.You live and learn. [/quote]
Probably correct, the engine temp at switch over will be the same summer or winter, but in the cold weather the lpg may be a few degrees colder at switch over than it would be in the summer this may be the difference.
I seem to get more lpg in my tank in the winter than the summer so the cold must have some kind of affect.
