Found a leak - what should i do?
Toby&Jules
Post by Toby&Jules » Sat Feb 16, 2013 7:23 pm
Evening folks. Just been out spannering the Bongo. Changed the oil, fuel filter and battery. It'd been a while since I lifted the seats, and discovered the tell-tale signs of a leak coming from where the top hose(i think) goes into the drivers side of the block, just above the water pump. I haven't actually seen it leaking yet, as it was getting dark by the time I fired it up.
If it is that particular hose that's leaking, I'm thinking it would be better to find a correctly sized jubilee clip to wrap around the end of the hose, without disconnecting it. I could then just bleed it from there. Am I right?
Toby
wonkanoby
Re: Found a leak - what should i do?
Post by wonkanoby » Sat Feb 16, 2013 8:20 pm
so its not the hose leaking?
its one of the hoses goes first and if it has never been replaced i would change it
Toby&Jules
Post by Toby&Jules » Sat Feb 16, 2013 8:49 pm
Forgot to say that. Ours has had a new rad and main hoses, so they look in fairly good nick. Hence why I'm hoping not to disconnect it.
Toby
windywatson
Post by windywatson » Sat Feb 16, 2013 9:17 pm
If the leak is from the end of the hose where it's pushed onto the water pump, then I would have expected that tightening up the clip that is fitted should do the job. Or perhaps new clip that is broader than the old one, so that is effectively sealing more hose surface to the water pump outlet.
As you have said that new hoses had been fitted, perhaps the water pump outlet was not cleaned up before the hose was pushed on. I find when changing hoses there is often a build up of scale/corrosion often caused by the alloy becoming corroded/reacting with antifreeze. I always wire brush the inlet/outlets that the pipes go onto to ensure that the surfaces are clean and smooth to enable best possible sealing.
Windy-Watson
2001 V6 Tin Top
Post by Northern Bongolow » Sun Feb 17, 2013 1:26 am
which bongo and engine have you got please.
Toby&Jules
Post by Toby&Jules » Sun Feb 17, 2013 11:44 am
Hi. It's a 96 tin top 2wd, with the 2.5 td.
Toby
wonkanoby
Post by wonkanoby » Sun Feb 17, 2013 12:08 pm
then i would bleed it
hijimhere
Post by hijimhere » Sun Feb 17, 2013 2:41 pm
Post by Simon Jones » Sun Feb 17, 2013 4:12 pm
Head gasket sealer is probably bit OTT for a leaky hose joint :). I would remove the pipe, clean the alloy mating surface and then refit with a new clamp & a smear of Hylomar gasket compound. Then full bleed of the system.
