Coolant system bleed procedure
Posted: Sat Jan 05, 2013 2:33 pm
by TerryG
I hope this isn't too stupid a question but as there are several fact sheets giving alternative methods of bleeding the system, does this mean that the official procedure in the Mazda handbook and manual doesn't work?
Re: Coolant system bleed procedure
Posted: Sat Jan 05, 2013 5:02 pm
by Simon Jones
No, just means folk have come up with some variations. The 'see saw' method seems to be a popular alternative. I made my own bleeding kit using a valve, pump and reservoir, so there's plenty of options.
Posted: Sat Jan 05, 2013 10:57 pm
by the1andonly
Simon
has your bleed system and kit been documented ?
any links?
Posted: Sun Jan 06, 2013 12:18 am
by Simon Jones
There's quite a bit of info here: http://igmaynard.co.uk/bongo/forum/view ... lit=Washer. I've made a few tweaks to it by fitting a switch for each motor so I've got better control of the flow, but it's basically working as the original prototype. When I get some time, I plan to make another smaller version which I can carry in the van.
Posted: Sun Jan 06, 2013 12:44 am
by Bongoplod
There are also 3 videos on Utube to show you how to do it
Brian
