comments on radiator and fan resistor faq
Posted: Tue Dec 11, 2012 1:52 pm
ive been having fun and thought the following might help others
radiator
i found that 1/4 drive extensions,the end that fits the ratchet
are just perfect to plug the oil cooler pipes to save wasting the oil
fan resistor
there is a large copper link piece on the lower side of the pcb
on mine it had come unsoldered,not sure if it was just this as removal buggers up the transisor any way
note you have to unsolder the 3 legs in order to remove the pcb dont try just pulling
http://www.dalbani.co.uk/catalogue/prod ... hp?id=4939
is a direct link to the transistor on the site mentioned in the faq
radiator
fan resistor
