Blue smoke when cold?
Posted: Fri Nov 30, 2012 1:06 pm
by Dr Fingers
Ruby (95 diesel) is very smokey when cold: light blue smoke, and smelly with it, but doesn't appear to be using oil excessively. It's really quite anti social and embarrassing. Have been using a light mix of veg oil, but have run that off and filled with a fresh tank of diesel, no difference, she still looks like there's a bonfire in the back....
Sailed through MOT two weeks ago, obviously was tested when engine was hot, so no problem when up to heat, but cold starts are not good.
My local Bongo man says "they all do it", but I can't believe that.
Can anyone suggest what might cause this?
Otherwise running sweet as a nut, and not a trace of smoke when warmed up. :?:
Derek
Re: Blue smoke when cold?
Posted: Fri Nov 30, 2012 1:40 pm
by Driver+Passengers
Are you losing engine oil?
Posted: Fri Nov 30, 2012 2:04 pm
by Dr Fingers
No, that's the strange thing..
Posted: Fri Nov 30, 2012 2:09 pm
Sorry, just read that you already wrote that in your first paragraph.
Perhaps you are, just not measurably yet. Turbo oil seals might be one...?
Posted: Fri Nov 30, 2012 2:26 pm
by Dr Fingers
Turbo was replaced a year ago, after blowing spectacularly. Now that was a lot of smoke :D
Keeping an eye on the oil, doesn't seem to be using more than usual. Just had a big service, but this smokiness when cold has always been a concern.
Derek
Posted: Fri Nov 30, 2012 2:29 pm
Hmm... sorry, can't help you. :(
Posted: Fri Nov 30, 2012 2:41 pm
by teenmal
Hi,sounds like a little unburnt fuel,does the engine have a slight misfire when it is smoking?It may be that the glow plugs are not 100%,or not staying on when they should.
Posted: Fri Nov 30, 2012 4:06 pm
by Dr Fingers
teenmal wrote:Hi,sounds like a little unburnt fuel,does the engine have a slight misfire when it is smoking?It may be that the glow plugs are not 100%,or not staying on when they should.
Plugs were replaced 6 months ago..but yes,. a little lumpy on cold tickover. How would I check if the plugs are ok?
Derek
Posted: Fri Nov 30, 2012 6:03 pm
by Northern Bongolow
how old is the air filter, and is it a good quality one.
if its old or a cheap one it could be getting not enough air for the amount of fuel while its on cold start, this will result in unburnt fuel going out the back end.
Posted: Fri Nov 30, 2012 6:28 pm
by Dr Fingers
Some good suggestions, many thanks.
Looks like new plugs and air filter might be worth a try..
Derek
