Page 1 of 2
				alloys
				Posted: Mon Oct 01, 2012 3:34 pm
				by Colin H F
				Re: alloys
				Posted: Mon Oct 01, 2012 3:53 pm
				by Hanksy
				for changing the size of the vehicles outer hub  to the size of the Alloy wheels internal hub,
				Re: alloys
				Posted: Mon Oct 01, 2012 3:54 pm
				by helen&tony
They're spigot rings to take up the slack on the wheels which have too large a centre bore for the Bongo fitment. If they are too large, then you should have them on all 4 wheels!
Ha...beat me to it
				Re: alloys
				Posted: Mon Oct 01, 2012 4:14 pm
				by Colin H F
				well that was the first thing that came to mind then I thought   can't be  there only made of plastic  and they don't  cover the entire bore of the alloys
				Re: alloys
				Posted: Mon Oct 01, 2012 5:16 pm
				by francophile1947
				Colin H F wrote:well that was the first thing that came to mind then I thought   can't be  there only made of plastic  and they don't  cover the entire bore of the alloys
My spigot rings were orange plastic - they only have to hold the wheel central until the wheel nuts are done up - there's no weight on them when driving.
				Re: alloys
				Posted: Mon Oct 01, 2012 5:24 pm
				by mikeWalsall
				Some wheels are stud mounted .. but Bongo wheels are spigot mounted and should fit into the 'lip' around the disc hubs ..
You should not rely on the wheel studs, as the wheel may not be accurately centred which 'may' cause wheel wobble..
				Re: alloys
				Posted: Mon Oct 01, 2012 9:50 pm
				by Colin H F
				francophile1947 wrote:Colin H F wrote:well that was the first thing that came to mind then I thought   can't be  there only made of plastic  and they don't  cover the entire bore of the alloys
cheers John That makes sense
				Re: alloys
				Posted: Mon Oct 01, 2012 9:51 pm
				by Colin H F
				mikeWalsall wrote:Some wheels are stud mounted .. but Bongo wheels are spigot mounted and should fit into the 'lip' around the disc hubs ..
cheers mike fully understood
				Re: alloys   spigots
				Posted: Mon Oct 01, 2012 10:01 pm
				by Colin H F
				john  where do I find out what size I need for the other two
				Re: alloys
				Posted: Mon Oct 01, 2012 10:56 pm
				by briwy
				Try giving Mike at Wheelquick a ring, he will sort you out.
				Re: alloys
				Posted: Mon Oct 01, 2012 11:39 pm
				by Colin H F
				cheers  will do
				Re: alloys
				Posted: Tue Oct 02, 2012 4:28 am
				by helen&tony
				Hi Colin
Measure the bore of the wheel centre.  The Bongo is  67.1 mm. The 2 measurements will provide the correct spigot ring dimensions (inner and outer measurement of the ring)...alternatively, it may appear on the other 2 rings, if you check that they're the right I.D., but a set of 4 rings is cheap enough on e-bay.
I think that most manufacturers make their wheels with a large bore these days, and supply a ring to fit various makes...both sets of alloys I have have rings...not keen on them myself, as my original alloys are correctly bored...BUT...it seems like there's little choice
				Re: alloys
				Posted: Tue Oct 02, 2012 12:09 pm
				by Colin H F
				Cheers H & H  I'll  have to take one of the wheels off again    Drat
     never mind
				Re: alloys
				Posted: Tue Oct 02, 2012 5:08 pm
				by Colin H F
				for got to put a photo up  of my newly acquired wheels  17" KOSEI'S    WEARING 215/60  17R 96H  Rubber's
				Re: alloys
				Posted: Sat Oct 13, 2012 1:10 pm
				by Colin H F
