I've noticed that it sounds a little as if the motor is struggling to pull the AFT down - towards the end. It might be my imagination though. I wondered if there was anywhere I could lube to make its job any easier?
Many thanks.
Lubing the AFT?
Re: Lubing the AFT?
Silicon grease on the runners
Re: Lubing the AFT?
..and try not to get over zealous or your tent will end up with greasy black spots where it touches
Re: Lubing the AFT?
You need white lithium grease, usually supplied in a spray can. Grease all the runners and the little wheels that run in the runners and make sure you get it into both the runners as there is one behind the other one that people usually miss.
Re: Lubing the AFT?
That's great - many thanks indeed! I will go & do before next weekend (when I'm camping again).
