fitting disc spare tyre on rear
Posted: Thu Aug 23, 2012 12:46 pm
by droodle
Just looking at the manual which is bad english and says ..
"emergency spare tyre cannot wear the chain, if the flat tire is at the back wheel the front tire remove to back and emergency spare tire must be set on the front wheel so that tire chain can be set the back wheel"
is this for 4wd ? only i have a 2wd.
Only need to pootle 2 miles to get a set of new tyres tommorow wasn't sure if i have to swop a whel from the front and put it on the back ?
thanks.
Re: fitting disc spare tyre on rear
Posted: Thu Aug 23, 2012 12:49 pm
by wonkanoby
think thats only if your using snow chains
Posted: Thu Aug 23, 2012 2:55 pm
by droodle
ah ok that would make sense - cheers.
