V6 RADIATOR BLOWN - Help Needed
bongomike
Post by bongomike » Mon Aug 20, 2012 10:35 am
Hi Guys
I just got home and my radiator is leaking all the way along the top seal. Does anyone know the part number so I can order one here in Australia. If not does anyone know anywhere in the UK I can get one from. I need it urgently it's our only mode of transport at the moment.
Are they worth repairing?
cheers BongoMike.
Re: V6 RADIATOR BLOWN - Help Needed
Post by francophile1947 » Mon Aug 20, 2012 1:01 pm
These people are selling them on Ebay in UK http://www.ebay.co.uk/itm/MAZDA-BONGO-2 ... 45ff7740cc
It might be worth emailing them to see if they know the part number.
Failing that, can't your local Mazda dealer help?
bongomike
Post by bongomike » Mon Aug 20, 2012 1:11 pm
Thanks for your help John. I've emailed him to see if he would post to oz.
I think I met you once. I used to live in Norwich and you dropped an under seat tray over, has your bongo got that pimped suspension?
Post by francophile1947 » Mon Aug 20, 2012 1:17 pm
Aha - I remember that :lol: I was, indeed, the one with the pimped suspension. I am now Bongoless (gone a bit bigger :-" ) but still enjoy the club and the friends, old and new 8)
Good luck with your search [-o<
cheffy34
Post by cheffy34 » Mon Aug 20, 2012 3:06 pm
DO NOT QUOTE ME :!: :!:
I could be wrong but i think it is the same rad as the diesal
worth checking out all the same
Dar
Post by Northern Bongolow » Mon Aug 20, 2012 8:14 pm
my thoughts on the rad, or anything else springing a leak under pressure is to replace the stat with a gen mazda one while the systems in bits too. :wink:
bongomike
Post by bongomike » Fri Aug 24, 2012 10:11 am
Thanks for all the advice guys, I managed to get the radiator out and it has been repaired, they took the top off and replaced the O ring. I'm going to refit it tomorrow.
Just one question when I took off a small pipes from the bottom which hold the oil in. Where do I top up this oil as I lost a few drops (not a lot)
cheers
Michael
Post by Simon Jones » Fri Aug 24, 2012 10:30 am
It's the ATF oil for the gearbox. You fill up the via the dipstick tube located at the rear of the driver's side engine compartment. Do a search on here for how to check the level as it's a bit more complex that just reading the level of the dipstick.
Post by mikeonb4c » Fri Aug 24, 2012 5:57 pm
bongomike wrote:Thanks for all the advice guys, I managed to get the radiator out and it has been repaired, they took the top off and replaced the O ring. I'm going to refit it tomorrow.
cheers
Michael
That is really interesting. Never heard of anyone managing (opting) to repair a leaking Bongo radiator by taking the top off and fitting a new O-ring. Heard stories about plastic top cracking and unit not being repairable, so thats a first for me. Well done that garage (the frontier spirit of Oz I reckon) =D> =D> =D>
Post by rita » Sat Aug 25, 2012 9:02 am
cheers
Michael
This is one of the sad stories of the Motor Trade,at one time there was a buzzing industry in Britain repairing and reconditioning radiators. :( almost every large town had a repair centre or two.
Diplomat
Post by Diplomat » Sat Aug 25, 2012 10:15 am
Now that's interesting.
I assumed that there was some form of seal along the interface, call it an O ring generically, and that is indeed the case.
Presumably, after a time it deteriorates, probably because of the heat at the top of the rad.
Well, that's my theory, anyway, as I wouldn't like to have the bottom one go. At least the top seal is easy to check and repair with epoxy.
I wonder what the Australians used? A genuine replacement, a length off a roll, or something squeezed out of a tube?
Frank
They flew, I took up naturism
