Steering rack.
- brorabongo
Steering rack.
Are all Bongo steering racks the same?
Mine is leaking. I can get a s/h rack, but does it matter if it's from a 2wd as mine is a 4wd?
On Lushprojects it lists 6 different racks.
Cheers.
P.S. Is it an easy-ish job to replace the seals? as I might refurb my old one in the future if so.
Cheers.
Re: Steering rack.
ive fitted a few and am not aware of any external differences, but maybe i was just lucky.
as far as i know there is only one seal recon kit available??.
as to how easy a recon job is have a look in the manual--------its the largest single subject in there 30 odd pages if i remember right, plus lots of specialist/home made tools needed.
- brorabongo
Re: Steering rack.
Thanks.Northern Bongolow wrote:ive fitted a few and am not aware of any external differences, but maybe i was just lucky.
Re the refurb...............I don't think I'll bother.
- Muzorewa
Re: Steering rack.
Re S/H rack if you get one from our local friendly (Friendee?!?) breaker, I'll be passing through Sutherland next weekend
- brorabongo
Re: Steering rack.
Thanks Muz.
Silly question though....Which friendly breaker are you thinking of?
Re: Steering rack.
ive got an old rack of mine, and a seal kit in stock, and im still not doing it. .brorabongo wrote:Thanks.Northern Bongolow wrote:ive fitted a few and am not aware of any external differences, but maybe i was just lucky.
- Muzorewa
Re: Steering rack.
http://stores.ebay.co.uk/bongobits4ubrorabongo wrote:Thanks Muz.
- brorabongo
Re: Steering rack.
With a bit of luck in the timing (he was due to pass through Brora) Muz went out of his way to pick up a Steering rack from the above seller and drop it off at my door, at some time of this morning that I didn't know even existed!!
Many thanks Muz, Your a Star!!
Also thanks to George at http://stores.ebay.co.uk/bongospares2012 for the great service, and allowing Muz to pick up the rack from his house outwith working hours.
Now only got to wait till the 11th to get it fitted.
Re: Steering rack.
good one paul.
ever thought of becoming a paid courier.
Re: Steering rack.
Hi I bought a s/h steering rack cos mine was leaking, now the s/h one is leaking twice as bad, wish I had just bought a new one to save changing it again.
Re: Steering rack.
Hi,stuc wrote:Hi I bought a s/h steering rack cos mine was leaking, now the s/h one is leaking twice as bad, wish I had just bought a new one to save changing it again.
might be worthwhile getting the pressure checked before you replace it (or seals) again.
Cheers.
Re: Steering rack.
Hi,stuc wrote:How would you check the pressure?
I would check the pressure with 2 pressure gauges,but if you dont have the equipment,your local garage should be able to carry out the tests.It is advisable to get a professional to carry out the procedure owing to the very high pressure that the pump produces.
Cheers.
Re: Steering rack.
Hi I have access to lots of equipment, so what kind of pressure gauges, where do they connect and can you adjust the pressure if it is too high?rita wrote:Hi,stuc wrote:How would you check the pressure?
Cheers.
Re: Steering rack.
Hi your gauges will need to have a capability of handling a min of 1500 PSI,with suitable high pressure tubes and valves,if you have these you can connect to the both ends of the rack/pump.Take the fluid temperature to 50/60%,be very careful.stuc wrote:Hi I have access to lots of equipment, so what kind of pressure gauges, where do they connect and can you adjust the pressure if it is too high?rita wrote:Hi,stuc wrote:How would you check the pressure?
Cheers.
PS do you have the equipment required.
Good luck.
