				Is it my window switch or the window?
				Posted: Sun Aug 12, 2012 5:37 pm
				by fidel21
				I have had a recurring problem with my driver window going up for nearly a year. I thought it might be the switch but it works sometimes like this.
- I open the window.
Then it will not go up again unless I leave the vehicle for say 10 mins.
Turn of ignition an go for a cuppa.
I return and turn on ignition (just to radio not engine or both) and the window goes up. It's like it charges up or something?
Has anyone else had this problem?
				Re: Is it my window switch or the window?
				Posted: Sun Aug 12, 2012 6:40 pm
				Its normally the wiring loom where it leads from the chassis into the drivers door, the wires break and you get intermittent operation.  Do search there are plenty of pictures and references to the problem and solutions!
				Posted: Sun Aug 12, 2012 10:18 pm
				by jaylee
				Yep, no mystery... I'd have to agree with Geoff. When you moved the door to get yer "cuppa" the loom wire reconnected..?!! Common fault.. See here...
http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=57231
				Posted: Sun Aug 12, 2012 10:28 pm
				by Bob
				Commonly affects central locking too.
				Posted: Sun Aug 12, 2012 10:33 pm
				by jaylee
				Door mirror & i've known the odd speaker has fallen victim as well Bob..!
				Posted: Mon Aug 20, 2012 7:14 am
				by fidel21
				Thanks for the advice gang. What should I do about the wiring loom, take it into the local bongo mechanic or is it something I could look at myself.
Not brilliant with electrics but ok with small fixes.
				Posted: Mon Aug 20, 2012 10:21 am
				by teenmal
				Hi fidel21,
              The Bongo Fury Shop stocks the harness.
Cheers..
				Posted: Mon Aug 20, 2012 10:29 am
				by fidel21
				What is the harness? And is there any posts on repairing or fitting one?
				Posted: Mon Aug 20, 2012 11:23 am
				by Velocette
				fidel21 wrote:What is the harness? And is there any posts on repairing or fitting one?
The harness is a collection of wires complete with all the grommets and connectors and fixings to attach to all the electrical systems in the door.  The connectors are in the drivers footwell, there are two pairs of connectors which snap together.  Remove the crescent shaped plastic trim from the footwell to find them.  It is best to poke these out between the wing and the door while you connect and disconnect.  Take off the door card, remove or cut a flap in the polythene if present and take a photo of the old harness.  This will be useful to get all the popper fixings in the right place they are swines if you get one in the wrong hole (how do I know this?).  The harness operates the mirrors, the windows, the central locking if fitted and the speaker.  Apart from the above fitting it is self explnatory.  I wouldn't personally use the hard plastic clip again on the hinge as that is what knackers the harness in the first place, I anchored my harness to it with a loop of self amalgamating tape.
				Posted: Mon Aug 20, 2012 1:06 pm
				by francophile1947
				Just strip the casing off the harness and you'll probably find the thick, black earth wire is the offending item - simple repair
				Posted: Thu Oct 04, 2012 8:50 am
				by Sam Tearle
				Hi, I have the same problem in that my drivers window goes all the way down on a single press and won'y generally come back up until key out of ignition then back in a minute or so later when window goes charging all the way up without me even touchingh the switch.
Did it turn out to be your switch or wiring?  My switch looks worn but reluctant to shell out £50 before checking.
Thanks, Sam
				Posted: Thu Oct 04, 2012 9:37 am
				However....I had similar symptoms and it turned out to be the drivers side switch. So don't rule it out
				Posted: Fri Oct 05, 2012 3:55 pm
				by Sam Tearle
				Thanks, thats my hunch, sam
