locking noise
Posted: Thu Jun 07, 2012 7:24 pm
by Luke and Debs
recently have found when opening the driver door i can hear the central locking trying to work on the other locks. it does not actually lock but makes a clunk sound as if it is trying to lock all the doors. all locks fine no issues there. just as u move the door back and forward can hear it going.
anybody had this or know what it is
cheers luke
Re: locking noise
Posted: Thu Jun 07, 2012 8:16 pm
by wonkanoby
sounds like a short in loom between door and pillar
Re: locking noise
Posted: Thu Jun 07, 2012 9:31 pm
If you have a L/B then its often the case that the supply is switched over to it for the other doors, if the L/B is low / flat then the other doors won't lock/unlock.
Re: locking noise
Posted: Thu Jun 07, 2012 10:53 pm
by jaylee
wonkanoby wrote:sounds like a short in loom between door and pillar
Or possibly a break in a live wire to & from the master switch & the system reconnecting & resetting at the CL relay with the door movement...?
Either way look at the loom between the door & pillar.. http://www.g8dhe.net/bwm/bwmanualp.htm?1995/Page_108
