Too hot for fridge to work or battery depleted?
Posted: Mon May 28, 2012 3:31 pm
We spent the weekend at a very hot Gurston Down hillclimb in our Freda but by Saturday afternoon the fridge had stopped working (it's a small Waeco toploader - can't remember if it's a CB-36 or a CB-40).
Normally the battery (a recent Energy Bull 80 Ah) easily lasts for a weekend away so I'm surprised it stopped this weekend. Starting the van enabled the fridge to start but without the engine running the fridge remained off. The instructions suggest some possible causes, 2 of which seem most likely:
1) Battery voltage too low or 2) Ambient temperature too high
1) is possible if the fridge were running for much longer because of the high ambient temperature but I still think it unlikely unless we had left something else on that drained the battery (we checked and don't think so).
2) is possible as the rear of the van was facing south (it's an end conversion) and there isn't a great deal of ventilation around the fridge. The manual says it should work at up to 55 deg C - is it possible it got that hot? N.B we always turn the fridge off at night as it's right by our heads so we wouldn't know if it worked later when the temperature had dropped but it didn't fire up Sunday morning so I guess not.
Has anyone had a similar problem and if so did you find the cause? Anybody else got thoughts on the cause and what we could do to prevent it happening again?
I have thought about getting a battery voltmeter fitted so I can see the state of the leisure battery.
