No reverse !!!!!!
Posted: Mon May 21, 2012 4:58 pm
by M 80NGO
Fear not fellow Bongoliers L'oreal is just fine, i was asked today about a friend of a friends 4X4 2.5 TD Bongo sorta thing, she was driving out of a carpark and had to stop then reverse to let another car in, but when she tried to select reverse it wouldn't go backwards, it'll drive forwards and if the rear prop is removed it'll roll backwards but with the rear prop attached it can't be rolled backwards.
Any ideas on either gear box, transfer box, of cardboard box ?
Thanx, Pete.
Re: No reverse !!!!!!
Posted: Tue May 22, 2012 4:28 am
by Northern Bongolow
have a look at the connecting cables underneath, and on the top end at the stick, you may just be lucky and one has come off. is it going into park, and the footpedal lock engageing.disengaging, just thinking it may not let you engage reverse if its not clearing.
Posted: Tue May 22, 2012 1:58 pm
by rita
Northern Bongolow wrote:have a look at the connecting cables underneath, and on the top end at the stick, you may just be lucky and one has come off. is it going into park, and the footpedal lock engageing.disengaging, just thinking it may not let you engage reverse if its not clearing.
This might give you a clue.....
Quote........
Posted: Tue May 22, 2012 2:21 pm
by crazy uncle gray g
:-k This Fella knows his stuff (Alacrity) , does this help
http://www.igmaynard.co.uk/bongo/forum/ ... ch#p534586
Or try and contact him through PM.....Good Luck
Posted: Tue May 22, 2012 6:28 pm
by M 80NGO
Thanx for the replies guys very helpful :wink:
Posted: Wed May 23, 2012 12:35 am
Quote........
you will have to make it a bigger clue than that :shock: .
the point i was making, maybe wrongly was that if its not coming out of forward, its never going to go backward.
