As above: just tried Tesco special offer Sunflower, immediate blocked fuel filter (I'm guessing, from symptoms). Or could this just be a coincidence? I put 20 litres in, on top of 2/3 full diesel, so roughly 30% mix. Ruby has been quite happy on rapeseed, but really doesn't like sunflower
Derek
Sunflower oil. a no-no
- Dr Fingers
Re: Sunflower oil. a no-no
I think sunflower oil is thicker than rapeseed and some brands contain emulsifiers that probably aint good for engines! At best your engine once your filter is cleaned will probably run on it but will be a bit rough!
- Dr Fingers
After 'jumping' Ruby up and down the drive, blockage seems to have cleared. However, once she was feeling better, trotted off and whacked some diesel in on top of the sunflower.
Seems to be running ok, but will change fuel filter (and air filter) later this week.
In the meantime, I have 60 litres of Sunflower going spare. Have perfected the art of Greek deep-fried Calamares, so looks like that's going to be on the menu here for quite a while..in fact, if we ever get to a meet, I might just have a giant calamares cook up....
Derek
Derek
Prob not the filter if now ok,just always best to mix out of the tank before you throw in.not as bad when warmer...it will be fine just maybe use a Lower mix..don't throw it away it looks like you just added too much that's all
- Dr Fingers
Thanks. She is running fine again, but I think it's worth a filter change anyway. I have no idea when it was last done, so it won't hurt. I was thinking of adding an in-line filterchipvan wrote:Prob not the filter if now ok,just always best to mix out of the tank before you throw in.not as bad when warmer...it will be fine just maybe use a Lower mix..don't throw it away it looks like you just added too much that's all
http://www.ebay.co.uk/itm/150479838563? ... 1952.l2649
Any reason why I shouldn't? Seems to me it would be much easier to replace one of these than the main one.
Derek
- rhino-wayne
Was the engine coldDr Fingers wrote:After 'jumping' Ruby up and down the drive, blockage seems to have cleared. However, once she was feeling better, trotted off and whacked some diesel in on top of the sunflower.
I have used sunflower oil in the past, no problems, but usually added after the engine is hot/ at operating temperature & then topped up/mixed up in the tank with diesel .
- Dr Fingers
'Twas cold, I must admit.
Lesson learned
Derek
Lesson learned
Derek
Dr Fingers wrote:Thanks. She is running fine again, but I think it's worth a filter change anyway. I have no idea when it was last done, so it won't hurt. I was thinking of adding an in-line filterchipvan wrote:Prob not the filter if now ok,just always best to mix out of the tank before you throw in.not as bad when warmer...it will be fine just maybe use a Lower mix..don't throw it away it looks like you just added too much that's all
Derek
yes i use them and you can see whats in there..put before main filter
