How to Replace Front Cabin Bulbs
Posted: Tue May 15, 2012 3:06 pm
by tonnee
I need to change the front cabin bulbs above the dash but cant get the lens cover off ?
Is there a knack to doing this ?
Tony
Re: How to Replace Front Cabin Bulbs
Posted: Tue May 15, 2012 6:25 pm
by maxheadroom
Posted: Tue May 15, 2012 6:43 pm
by jaylee
Max is right!
Two clips either side hold the whole unit into the head lining, pull it down, disconnect the wiring. (You will see a 2 pin connector when you pull it down.) 4 clips hold the clear lens/defuser into the housing, (its easier to take apart out of the head lining.) then you can accesses the bulbs...
Posted: Tue May 15, 2012 8:24 pm
Push the whole unit to the left or right, and then pull downwards from the opposite side, this helps release one clip that can then be pulled downwards.
Posted: Tue May 15, 2012 8:34 pm
by Bongo??
g8dhe wrote:Push the whole unit to the left or right, and then pull downwards from the opposite side, this helps release one clip that can then be pulled downwards.
Yeah,second that,just done this myself,thought i was going to break something doing it!!
Posted: Wed May 16, 2012 8:45 am
by tonnee
Easy when you know how !!
Cheers Guys
