Tyre pressure rule of thumb
Posted: Mon May 14, 2012 3:15 pm
Those of you who are vexed by the question of the correct tyre pressure might be interested in this method of finding the optimum. It came from an Australian camper van website and is identical to the advice offered on a couple of American automobile forums:
1. Measure and record the cold start pressure of your tyres before you start out.
2. Drive for a distance of approximately 100Km.
3. Recheck the tyre pressures immediately after pulling over and compare them with the the cold start pressure you had at the start of your run. If the pressures are right, the hot readings should be 4 psi (28 kPa) higher than the cold start readings.
4. If there is a greater than 4psi (28 kPa) difference between these pressures, the tyre temperature is too high caused by the cold start pressure being too low so the pressure needs to be increased. If there is less than 4 psi (28 kPa) difference, the cold start pressure is too high and needs to be lowered.
5. Large 4WD tyres will have a differential of 6 psi (42 kPa).
6. Be sure to use the same accurate gauge for both readings (NOT fuel station gauges)
