leaking steering rack, is it an MOT failure?
Posted: Thu May 10, 2012 8:44 pm
by surfbus78
Hi guys,
i've got a slight leak from somewhere on my power steering rack. though the steering works perfectly. does anyone know if this would consititute an MOT failure?
cheers in advance
Steve
Re: leaking steering rack, is it an MOT failure?
Posted: Thu May 10, 2012 9:11 pm
by scanner
I'm pretty sure it will be a failure any leak usually is.
Posted: Fri May 11, 2012 4:30 am
by Northern Bongolow
try a bit of powersteering system leak fixer from your local factors, then wipe the affected area clean
Posted: Fri May 11, 2012 8:50 am
by surfbus78
good plan, i'll get some of that from halfords.
I've already cleaned up the rack in situ with de-greaser and it looks a lot tidier.
Steve
Posted: Fri May 11, 2012 9:02 am
by mentaliss
surfbus78 wrote:Hi guys,
cheers in advance
Steve
absolutely yes
Posted: Fri May 11, 2012 9:18 pm
by surfbus78
think i am in the clear, rack doesn't seem to the leaking, the fluid is still on max. It looks like the gunk over the rack is caused by throw-off from the offside front prop shaft as there is a slight leak from the diff and its flinging oil off it centrifugally!!
Posted: Sat May 12, 2012 4:06 am
this could point to tyre issues, are your tyres/wheels the right size, and all the same tread depth as its important on a 4wd.
or is the diff breather blocked (they usually are). to check the breather look on the top you will see a nipple thing, grab it and screw and lift until its free.
