Crank shaft oil seal front
Posted: Thu May 10, 2012 1:54 pm
by delbouy
Can anyone tell me if it is a big job to change the front crank shaft oil seal
Re: Crank shaft oil seal front
Posted: Thu May 10, 2012 2:50 pm
by teenmal
No its not a big job,about 20/30 minutes (all going well)
Make sure the IP seal is not leaking.
Cheers.
Posted: Thu May 10, 2012 8:00 pm
by delbouy
Thanks for the reply but can tell me what an ip seal is
Sorry if I'm being a bit thick
Posted: Fri May 11, 2012 11:24 am
by teenmal
Hi delbouy,
There is also another oil seal,(Injector Pump pulley seal)On the timing gear cover,but I would think it more likely that it would be the crankshaft seal.It was just an after thought.
Good luck.
