cv joints for 4wd friendee 1996
Posted: Mon May 07, 2012 10:44 pm
by paulquinn
am looking for 2 front bottom ball joints
where do i look?
help?
paul quinn
Re: cv joints for 4wd friendee 1996
Posted: Mon May 07, 2012 11:15 pm
by Northern Bongolow
which is it your after mate, :?: the cv joints and the bottom ball joints are two seperate items.
Posted: Tue May 08, 2012 10:41 am
by teenmal
Posted: Tue May 08, 2012 8:15 pm
by paulquinn
teenmal
thanks for your help! its definitely ball joints i am looking for. these are a great price. before i buy them, do you know if they fit both right and left hand sides, as they say they will?
thanks again
paul quinn
Posted: Tue May 08, 2012 10:46 pm
by paulquinn
teenmal
thanks again - i have discovered that i need ball joints with arms can ye help?
paul
Posted: Wed May 09, 2012 2:57 am
ava leisure or ian at the bongo shop on here, if they havnt got them they are on order.
blueprint do them at any good motor factors.
and eurocarparts are said to stock them, not sure of the quality/price though.
and mazda can order them, but not sure there are any in england, europe is next day, if not its japan in 10 days to god knows.
if you can get the ball only i would grab them as this item is in VERY short supply due to the mot rubbers regs that came in recently.
the ball joints are not handed but the arms are. any good garage could press in/out new ball joints if the arm is not rotten.
Posted: Wed May 09, 2012 10:41 am
by teenmal
Hi Paul,
You are doing the correct thing by renewing the arms,Mazda Do not recommend that (only) the joint should be replaced.
That is the reason Mazda do Not supply the ball joints for these vehicles.
http://www.ebay.co.uk/itm/MAZDA-BONGO-F ... 2a1ca8db8a
And the right hand. o/s
http://www.ebay.co.uk/itm/MAZDA-BONGO-F ... 27c64fdc46
Posted: Thu May 10, 2012 3:32 pm
by mikexgough
These wishbones are pukka Mazda genuine ones..... :wink: from this seller....
teenmal wrote:Hi Paul,
Posted: Thu May 10, 2012 4:47 pm
by mikexgough
The seller has the wrong price on the link..... he sells at £157 each or £295 per pair...... UNLESS.... he has decided to add £500 on the price in one day.... :lol:
Posted: Fri May 11, 2012 1:53 am
by mikexgough
Just a quick add on... the Part Numbers on these wishbones are different than the Lushprojects.....
Having checked with Japan..... they are the same part numbers used there....
BONGO LOWER WISHBONE ARM RIGHT S10H-34-300A
BONGO LOWER WISHBONE ARM LEFT S10H-34-350A
Both complete with Ball Joint...
