				Front drop Links
				Posted: Sat May 05, 2012 12:20 pm
				by georgey
				Hi Guys, decided to change my front drop links and ARB bushes any tips on how to get old nuts off? Thanks Geoff.
				Re: Front drop Links
				Posted: Sat May 05, 2012 12:43 pm
				by westonwarrior
				soak in penitrating fluid (wd40) and use an extension on the spanner/socket set
Or in extremes an angle grinder
				Posted: Sun May 06, 2012 9:49 am
				by lazyb5
				Brute force and swear words also an extension bar on your ratchet helps
				Posted: Sun May 06, 2012 9:54 am
				by Simon Jones
				Drop links sometimes require use of angle grinder to chop the nut off. Roll bar bushes can be tricky: I managed to shear a bolt on mine, so had to have the captive nut drilled out and new nut and bolt fitted.
				Posted: Sun May 06, 2012 5:49 pm
				by Northern Bongolow
				just done all mine today and new wishbones as i had a ball joint rubber split.
be prepared to cut off the droplinks, and a good tip from lazyb5, lubricate the anti rollbar bushes with grease when reassembling as per the manual.
				Posted: Thu May 10, 2012 12:46 am
				by Blueskai
				If the old ones are self locking, the locking is caused by having plastic in the thread, you can tell by the presence of a coloured ring around the bolt.  I removed mine by getting a blowtorch on it, repeatedly heating the nuts and loosening them until they gave up.  It worked a treat.
Unfortunately the new Bongo I have doesn't have this and so it was angle grinders at dawn and a very happy son who watched the fireworks from the opposite side of the road.  Note to self -  wear a hat for the nearside one!
