ECU
Posted: Fri Apr 27, 2012 7:18 pm
by cheesecake
There is a single wire coming out of one of the pins from the ECU ,its not pin 2 to test throttle sensor ... any ideas what its for ?
Re: ECU
Posted: Fri Apr 27, 2012 7:24 pm
by Simon Jones
Diesel, V6 or 2 litre petrol?
Re: ECU
Posted: Fri Apr 27, 2012 7:44 pm
by cheesecake
hiya , Its 4 wheel drive 2.5 diesel turbo.
Re: ECU
Posted: Fri Apr 27, 2012 10:07 pm
by Driver+Passengers
Could be for reading error codes, but who knows...
Got a picture, or can you describe which one it is?
Re: ECU
Posted: Sat Apr 28, 2012 2:30 am
by jaylee
Driver+Passengers wrote:Could be for reading error codes, but who knows...
I would think along the lines of error code reader mod too..!??
Re: ECU
Posted: Sat Apr 28, 2012 9:07 am
by Simon Jones
Wiring diagram can be found here which may be of help:
http://www.g8dhe.net/bwm/
Are you refering to the actual ECU (which will have lots of wires coming out of it) or the black diagnostic socket? Unless you have a problem, then it may well be best to leave it well alone: if it ain't broke, don't fix it
Re: ECU
Posted: Sun Apr 29, 2012 3:36 pm
by cheesecake
The wire is coming out of ECU middle connector , 6 pins along green wire with red stripe .
Hope this helps ? and cheers for your replies.
Re: ECU
Posted: Sun Apr 29, 2012 4:01 pm
cheesecake wrote:The wire is coming out of ECU middle connector , 6 pins along green wire with red stripe .
Code: Select all
[TAB]
2O 2M 2K 2I 2G 2E 2C 2A
2P 2N 2L 2J 2H 2F 2D 2B
Assuming you're counting from the left, then it is perhaps either pin 2E or 2F.
Looking at the older wiring manual page for the ECU (
http://www.g8dhe.net/bwm/bwmanualp.htm?1995/Page_30) and deciphering the colors (
http://www.g8dhe.net/bwm/bwmanualp.htm?1995/Page_7), it looks like 2E is green with a red stripe.
According to the Service Manual (page 81), 2E is "Vehicle speed signal 2", connected to "Speed sensor 2".
That you have three connectors suggest you have automatic transmission, and if the wire colours in your van are consistent with those in the wiring manuals, then have an M, N or P reg. Correct?
Curious. (Though I'd tend to agree with Simon - if it ain't broke...)
Re: ECU
Posted: Sun Apr 29, 2012 5:47 pm
by cheesecake
Thanks for that , its a 96 automatic its pin 2f is that the one to check throttle sensor ? my gear box keeps going into limp mode ,one sec on one sec off .
Re: ECU
Posted: Sun Apr 29, 2012 9:18 pm
Service manual says 2F is "Engine rev signal (input)" connected to "NE sensor".
