Page 1 of 2
Roof doesn't work- please help
Posted: Tue Apr 17, 2012 4:16 pm
by Risoundz
Hello
The Roof has been working fine up to a few days ago.
It's in Park, hand brake on engine running but when I press the switch no beeping no movement.
I believe it can be a fuse or the switch that is faulty.
can you please give me a few tips on what to do?
what to check first.
thanks
Ricardo
Re: Roof doesn't work- please help
Posted: Tue Apr 17, 2012 4:45 pm
by francophile1947
Are you sure the handbrake is fully on? - is the warning light lit?
It's quite common for the little handbrake switch to need cleaning.
Posted: Tue Apr 17, 2012 5:25 pm
Yup its normally the switch and the dashboard light is the giveaway! but the fuses are;
ElectronicsImage
Motor powerImage
Posted: Tue Apr 17, 2012 6:24 pm
by Risoundz
no warning lights are on.
I will check the Handbrake and the fuses.
I'll let you know.
Thanks for helping.
Posted: Tue Apr 17, 2012 10:10 pm
The Brake light is what we are talking about if that doesn't come on with the Handbrake then the roof won't go up, its uses the same signal.
Posted: Wed Apr 18, 2012 8:15 am
g8dhe wrote:The Brake light is what we are talking about if that doesn't come on with the Handbrake then the roof won't go up, its uses the same signal.
Blimey, I didn't know brake lights came on with handbrake. Do you mean the brake warning light on the panel?
Posted: Wed Apr 18, 2012 9:03 am
by 321Away
I think they do mean the indicator light on the dash
Julian
Posted: Wed Apr 18, 2012 10:25 am
Well the Brake light doesn't come on with the Footbrake .....
C2-05 is the Handbrake switch that lights the lamp as also will C2-06 which looks at the brake fluid reservoir.
Posted: Wed Apr 18, 2012 1:23 pm
by Metalpetal
Looking at this thread has made me wonder whether it's a good idea to buy a set of spare fuses to keep in the van in case we need them in emergencies? If something like this happened when you were at a campsite, and couldn't get the roof down...and it was a fuse that was the issue, it would be darned handy to happen to have a spare one to hand!
Anyone got any advice on which to buy? Is there a type of 'spare fuse kit' I can get?
Thanks (sorry if this sounds obvious!)
Mp
Posted: Wed Apr 18, 2012 1:28 pm
by dunslair
Metalpetal wrote:Looking at this thread has made me wonder whether it's a good idea to buy a set of spare fuses to keep in the van in case we need them in emergencies? If something like this happened when you were at a campsite, and couldn't get the roof down...and it was a fuse that was the issue, it would be darned handy to happen to have a spare one to hand!
Mp
Ian used to stock them in the BF shop, you could try giving him a call to check they are in stock. We keep a spare set in the glove box.....somewhere. :wink: :D
Posted: Wed Apr 18, 2012 1:41 pm
Yes its worth while getting a little kit of spare fuses for the Bongo, with the way people use a Bongo there is a much greater chance of having some additional electrical item causing a fuse to go. The Bongo shop has kits http://www.igmaynard.co.uk/bongo/mercha ... #Electrics but remember to Log in to the site if your a Club member to get the discount!
Posted: Fri Apr 20, 2012 9:12 am
by Risoundz
Hello.
Sorry for my delay replying but I pulled a mussel on my back and I've been in pain for a while.
No lights come on when I use the hand brake.
Is it a fuse or Just bad contact on the cable?
thanks
Posted: Fri Apr 20, 2012 9:29 am
by dave_aber
Most likely a poor contact at the handbrake switch.
Lift off the centre console cover, and look at the back of the handbrake lever - there is a switch of sorts there. It is quite open, and can get all manner of fluff & dirt in the contact points. The wire may have fallen off.
Clean / repair / fiddle with it until the Handbrake / Low fluid warning light on the dash comes on.
If it sin't lit, the roof won't budge.
Posted: Fri Apr 20, 2012 2:30 pm
by Risoundz
I will try that tomorrow.
Thank you very much for helping.
Posted: Fri May 04, 2012 1:45 pm
by Risoundz
Hello.
I ended up not doing anything. The brake light just came up again and the roof is working again.
I have a 1999 V6 new shape and I never turn the head lights on because the sensor does it for me.
suddenly it stopped working.
I don't know how to turn it on and off and I always wanted to know.
Does anyone know how to turn the sensor on and off.
I'm probably having some electric probs
Should I check all the electrics?
thanks
Ricardo
