Oil type and pressure
Posted: Tue Apr 10, 2012 11:27 pm
by winchman
My Bongo runs fine but when I first start it it trakes a few seconds for the oil pressure light to go out?
What type and grade of oil are people using?
Re: Oil type and pressure
Posted: Wed Apr 11, 2012 2:37 pm
by francophile1947
I always used 10W/40, but the recommended is 5W/30.
Posted: Wed Apr 11, 2012 5:49 pm
by winchman
The service history shows 15w40 semi sythetic?
Posted: Wed Apr 11, 2012 6:21 pm
by francophile1947
Most garages use 10W/40 as their stock oil - 15W/40 is a bit thick and could explain why the light stays on longer (takes longer to circulate). I wouldn't worry as long as it goes out and stays out.
Does it do it even when the engine is warm?
Posted: Wed Apr 11, 2012 11:27 pm
by winchman
Going to change it of Friday to 10w40 as its due
Posted: Thu Apr 12, 2012 12:01 pm
by teenmal
You could try changing the oil switch,this lag is usually associated with worn oil pump or main bearings( if the oil switch is OK)How long does the light actually stay on.??
The only way to see whats happening is test it with an Oil Pressure Gauge.
Cheers.
