I just butchered an old clock unit for my temp gauge fitting...[/quote]
I have an old cassette player where your temp gauge is.... ill be able to bodge something
Bought some speakers today, after a lot of messing about i thought the easiest and best solution was this,
Click me:
Easy enough
Although i broke one of the small door pockets on the passenger side, the screw was very tight and i snapped the small trim whilst trying to undo it. Ill throw up a pic at some point, anyone know where i can get a spare or one that fits?
Got fed up trying to make the original mounts and new mounts fit. So....
Used the connectors from the old speakers so i didn't have to butcher the Mazda wiring.
Seems ok to me, didn't take that long. Couple of hours maybe, spent more time messing about trying to make the old pod fit with the new mounts, id still be out there if I had of done that!
Had a quick check around the Bongo whilst i was out there,
Bleed pipe was lose so i out it back and chucked a cable tie around it to make it stay!
There was a small tiny bit of coolant on the end of the bung, i will keep an eye on it. I checked the levels and it was fine, i used a dry cable tie to see where the coolant came to then measured it next to the min/ max levels. It was just above max. When i pulled it out there was a layer of rust on the bottom of the header tank. Radiator going maybe?? Going to take it to bell hill for a service in near future and a coolant system health check. Ill ask then maybe.
Couple more pics,
Drivers side, seemed ok apart from one area.
Bit oily up there, what is this? Its top right of the original drivers side pic.
sorry for the long post, bit excited today!
As i have two weeks off, had my appendix removed last Thursday. I plan on doing some bits and bobs!
